Question about Intel Motherboard
Intel 815E Mother Board
Dear Sir,
I have Intel 815E Mother Board With P3 800 Mhz Processor and 256 MB SDRAM
My SMPS IS Going
  • 196 Answers
Do you mean the Power Supply?
These are relatively cheap and easy to replace.
Posted on Dec 04, 2007
SOURCE:
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
What is the max memory that i can install on an intel motherboard e210882
The Dell E210882 system board is compatible with PC2-3200 (400 MHz) or PC2-4300 (533 MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Capacities compatible include: 128 MB, 256 MB, 512 MB or 1GB. The maximum installable RAM is 4 GB.
let me know if it helps you : ) replay to me as soon as you solve your problem : )
Sep 15, 2011 | Intel Motherboard
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Upgrade beyond limits
if you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
Nov 29, 2007 | Sony VAIO Digital Studio PCV-RX550 PC...
Intel Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
