Question about Epson DFX-9000 Matrix Printer
Micro feed locked
My printer DFX 9000 cannot adjust its micro feed. It says as it is locked. How can I open its micro feed lock
  • Epson Master
  • 1,113 Answers
Font and pitch hold down and turn on printer at power switch and please rate at least as FixYA
Posted on Dec 03, 2007
  • Soulvisitor
    Soulvisitor Dec 03, 2007
    I know you don't have a cc but you can rate as Fixya
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Error 11 what is mean
ER 11 means of ribbon feed error.
please check : ribbon feed motor , ribbon feed ic driver motor and main board .
Apr 24, 2009 | Epson DFX-9000 Matrix Printer
DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Dec 17, 2008 | Epson DFX-9000 Matrix Printer
No puedo configurar el top form de la impresora
aprendizaje hablar español :)
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
No he intentado traducir las instrucciones mientras que puede causar la confusión.
Sep 10, 2008 | Epson DFX-9000 Matrix Printer
Error 07 ,turn off Printer on dfx 9000
Timing fence could be faulty or dusty. Clean it and test if that fails replace it.
Jul 23, 2008 | Epson DFX-9000 Matrix Printer
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
Alpha seting of dfx 8000 printer
The purpose of this adjustment is to set the PG offset value in accordance with the nose dimension
of the printhead. (For details, refer to Chapter 2.)
The offset for the nose dimension is represented by the adjustment value “ALPHA.” The “ALPHA” value
is stored in the memory on the main board, so the PG adjustment mechanism can read the value as
needed. Be sure to perform the adjustment when required. If this adjustment is not performed correctly,
the platen gap will be incorrect, the paper could be caught by a head pin, or, in the worst case, a head
pin could break.
NOTE: The printhead adjustment value is written on the front of the head unit (refer to Figure 4-2). After
the printhead is attached, the value cannot be seen. Be sure to write down the value before
attaching the printhead.
Step 1: Connect the AC cable. Mount the ribbon cassette, and load paper into the front tractor.
Step 2: Turn the printer power on while pressing the LINE FEED, MICRO FEED (V), and PAPER SELECT
switches (Be sure that the top cover is closed. Do not open it until you turn the printer power
off.), then wait until the buzzer rings five times.
REV.-A
Step 3:
Step 4:
Step 5:
Step 6:
Load the paper by pressing either the LINE FEED or PAPER SELECT switch, then wait until
the PAPER OUT lamp goes off (approximately 15 seconds).
Press the ON LINE switch.
Press the MICRO FEED (A) switch the number of times indicated by the value written on the
front of the printhead.
l The buzzer rings each time the MICRO FEED switch is pressed.
l Press the MICRO FEED (A) switch to increment the value.
l Press the MICRO FEED (V) switch to decrement the value.
l The value range is O to 10.
To confirm the value stored, press the FORM FEED switch so that the value is printed.
l If the value is incorrect, return to Step 5.
. When the value is correct, go to Step 7.
Step 7: Press the ON LINE switch and confirm that the buzzer rings five times. The printer prints the
final value stored. If the value is correct, turn the printer power off.
Dec 06, 2007 | Epson DFX 8000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
387 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
