Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
Motherboard when i start the power the small light in the board is open and the CPU pan is running but ther is no any boot is appear in my monitor..........can u give me a solution please sir .........the video card that i put is work in other board.....please...sir!!!!
  • 62 Answers
Your problem is your hard drive. not your video card. use your windows installation disk and boot from it. then when your first set of options pop up press r to repair your hard drive.
Posted on Dec 03, 2007
Optiplex 320 wont boot. Amber power light and fans running
power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Feb 17, 2012 | Shuttle sn Computers & Internet
No Display on boot up
When a motherboard does not beep that isnt good news and its either the Motherboard or CPU. Have you fot the FSB settings correct on the board? Is your power Supply Good? Does your graphics card need power and is it plugged in? Unfortunately the only way to findout exactly is at fault is through a process of elimination. Can you try a different power supply first? Also try removing the CPU and re-seating it. If not, then you need to try and get hold of another motherboard and see if everything works in that. If not then it could be the CPU. Diagnosing CPU or MOTHERBOARD is always tricky without spares. Good luck
Aug 30, 2007 | ASUS P5NSLI (0610839134670) Motherboard
Cpu fan works, power supply fan works why wont' computer come on?
Could be a number of reasons:
The CPu fan and the PSU fans will come on, even though the system is not working. There is a possibility that the CPU has blown, you can check this easily by (carefully) feeling the heatsink after it has been running a while. A dead CPU will not use power and therefore not heat up. If after say 10 minutes of running, the heatsink is clay cold, suspect the CPU. Replace with another one, spreading CPU grease on the top before putting the heatsink back on.
A blown CPU will usually be indicated bu there being NO beeps from the system (see below)
If the CPU appears to be generating heat, visually inspect the board, look for blown or blowing capacitors (the small cylinder like components) on the motherboard, any that are bulging or leaking a brown residue, or have blown, will render the motherboard inoperative.
If these appear ok (they still may be damaged), unplug all components except the hard drive, and ram and video card, see if the system then boots. If it does, proceed to re-installation of each in turn, until the faulty peripheral halts the boot.
Listen for any beeps as the ssytem switches on these beeps describe the type of problem
(repost if you hear any beeps)
Remove one stick of ram and try rebooting, if it works, suspect the ram module, try the other and see if that makes any difference.
Failing that, your last recourse is to power the system off, remove the bios battery, replace after 2 minutes and see if clearing the Cmos "unsticks" the computer.
After That, suspect the motherboard is dead.
Apr 25, 2011 | Computers & Internet
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
I have an Emachines 620 and it wont boot up. The 3v Battery was dead so I took the one out of the remote but its still not booting. DVD drive open and closes but CD drive doesn't. Fans are running and...
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Oct 26, 2009 | E-Machines (306785) Motherboard
Won't start - tested power supply - it is good - removed cards and drives still nothing. Board looks okay - no holes - canisters are flat - what next?
re-seat the memory - how did you check the power supply - its fan working does not mean it functions properly - if you have spare try that one.
Sep 01, 2009 | E-Machines T3085 PC Desktop
The thing will not boot up. ive gone over every connection a dozen times, everything seems to be connected correctly. the front led lights work and when i press the power button the system and fans all...
The best way to troubleshoot the issue is to strip down the motherboard to just the CPU, and then apply power. If it behaves normally you would then begin adding items back on starting with your memory. The idea is that you keep adding items until the problem you describe appears. The last item that you added on would then be the issue. If you are not able to get it to boot with just the CPU onboard, then you either have a motherboard issue, or as you stated, a CPU issue. The only way to identify which it would be is to either try the CPU on another board, or try a different CPU on your board. Your board might have a set of diagnostic beeps built in. If you start getting beeps with just the CPU onboard, check your owners manual to identify the issue. It should only give you a code stating that it is missing memory and other items.
Aug 08, 2009 | ECS KN1 SLI Lite (V1.0A) Motherboard
Computer can't boost up
There are a host of things that could cause this. The first thing to check is to mak sure you have the proper memory setup for your motherboard. Often these days you need to install memory in pairs for the board to boot. Refer to your motherboard manual and make sure the memory you have installed is right fro your board and that you have it installed in the right slots. If you do and it still doesn't work, please reply with your motherboard, CPU and memory specifications so I can look into this further.
Jun 18, 2009 | Computers & Internet
Computer does not boot
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Apr 20, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Start up
That message will appear when there is no boot record found on any device the system board tries to boot from. This probably means that your hard drive is not being detected, does not have a bootable copy of Windows on it, or is defective.
Make sure the drive is correctly listed in the motherboard setup screens. If it is not, check for proper power and data cable connections at both the drive and main board. If the drive is being correctly identified, you may need to reinstall your operating system.
Jan 20, 2009 | Intel Motherboard
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
