Replaced sensors today in my LG Front Load washer, worked for one load, now will not spin and makes a load banging sounds when attempting to spin on spin cycle. Any ideas what might be the issue?
Replace the motor position sensor also known as a 'hall' sensor. About $20. Pretty easy fix. Check out videos on , repairclinic.com , , appliancepartspros.com , or YouTube.com.
Pretty common erroron older units.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - 189 reviews - $32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
It could be caused by loose or damaged bearings or even damaged belt. You might have to replace worn out belt and bearings. Also find out if the washer is sitting on an uneven platform. Make sure the floor is even and the machine is not tilting.
Hi dear.According to your explanation,you washer's drum bearings worn out(GONE)It needs to be replaced but it's a expensive job & complex task.Call service centre for cost of replace,make your decision.I hope that helps.Thanks.
We have a front-loading LG washer. Today, I took a look at it when it
was beginning the spin cycle because it sounded a bit different. I
noticed that it was beginning to spin and would stop because [I
believe] it was detecting a strong off-balance. It would then try to
spin in the opposite direction and the same happened. After two more
attempts, it automatically shut off with no warning nor error. We set
the washer to wash and spin again and I began to work on balancing it.
After adjusting the feet and waiting for the spin cycle again, it
continued successfully because of the reduced off-balance. I'm not sure
if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
With a 10 year warranty on their direct drive washer motor, eliminating a clutch or transmission, those enerty star LG's generally preform very well. (one of my customers runs 10 loads a day, 365 days a year in his)
Sounds like the shaft may have seperated from the three spider arms which actually turn the drum. To remove, you may have to grind end of bolt off motor shaft to facilitate dissassembly. It's a rather involved process. Prevent future mold and mildew issues by cleaning out the drain filter and then using a front load washer cleaner on longest, hottest cycle with no clothes (like ahfresh or washer magic, or whirlaway hot tub cleaner, to name a few.) then use not more that one tablespoon of HE detergent and a max of a teaspoon of fabric softener (if you use it) per load, as these machines are using very little water. (when you split the tub to replace the drive spider, use a pressure washer to clean out the inside of the outer drum and the back side of the inner tub) BTW, I have not found any reason to not stick with my LG washer and dryer. My seven year old set worked many a load, and still works great.
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
