Question about Panasonic KV-2025C
Scanner stops scanning and loses info
Scanner stops in the middle of a job, program shuts itself down, all images scanned through machine in that batch are lost, then no response and everything has to be re-booted!?
  • 62 Answers
Motherboard is overloading. uninstall in device manager without disconnecting then add new hardware wizard will guide you through everything.
Posted on Dec 03, 2007
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
Using my F380 all in one, how do I scan to my
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and turned on.
The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are finished.
To stop scanning ➔ Press Cancel on the control panel.
If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
or this if you have Vista:
If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
If this is the case then you can download a free program called IrfanView from there site:
Click the Start icon. Click All Programs .
Click Windows Photo Gallery .
Click File and then click Import From Scanner or Camera .
Click Import .
Click Scan .
I hope that helps..
May 26, 2010 | HP DeskJet F380 All-In-One Printer
How to scan a document
here you have an example about how to scan using microsoft scanner wizard ...
but ,,most scanners came with it's own program ...just click on the manager that came with the scaner ...locate scan button ..and scan ...after complete the job it will guide you in the folder where it stores the images...from there you can manage print or copy ...paste to another location ...or use the import from device feature to import the scanned images..
Jan 22, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
When I turn on my computer in the morning, often times my scanner is trying to copy even though I was not in the middle of trying this when I shut it down. How do I find out why & stop it?
The scanner is not trying to copy. It is putting itself through a power on self test to determine readiness for anything you might wish to scan.
Apr 21, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
I260 insufficient memory error
If you start scanning Documents over 17 inch, then its best to swap out the 64mbyte for a 256mbyte card on the mother board cpu 100/110.
You can tell wants loaded by looking at the Info tab in the Kodak Scan Validation Tool.
Nov 03, 2008 | Kodak I260 Captiva IA-Express Path-Through...
FIne art scanning - uneven color across scans especially at edge of bed
The problem is going to be with the bulb itself. The scaner you are using is not made to do such precise work. The bulb itself is undersized for such a large scale job. You can look into upgrading the bulb of your scanner but I would not sudgest it unless you go to an authorized dealer/maint contractor for your Microtek to find the proper upgrade.
Apr 28, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Scanner begins to hang.
Increase the size of the virtual memory or add RAM memory to computer. Check the Technical Support team at Canon also
May 25, 2007 | Canon DR-9080C Path-Through Scanner
Panasonic KV-2025C Logo
82 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
