Question about Brother HL-2040 Laser Printer
BROTHER HL - 2030
Tried the solution for a continuous toner light being on but machine is now just left running/huming and I still can't print.
Any further tips
  • Brother Master
  • 1,113 Answers
The solution that you tried, does that mean that you purchased a new brother toner and fitted to machine?
Posted on Dec 20, 2007
Howe do I clean the printer head, on my HL 2030? I am working with a mecbook.
Looking for brother printer technical support phone number 1-877-778-89'69 then you can call on this number our experts surly help you.
EFFICIENT QUICK AND RELIABLE TECHNICAL SUPPORT ON BROTHER PRINTER TECH...
Aug 26, 2016 | Brother HL-2030 Laser Printer
Brother hl-2030 - hi, is it possible to know how many pages a drum has printed?
Most laser printer do not have a page counter, because the toner cartridge may come in a couple of toner sizes and there is no way of accurately determine how much tone is used on each page as this can vary considerably.
If the printer gives a message that the toner is low, you can get several more prints by shaking the toner in a horizontal position and placing it back into the printer.
Dec 02, 2010 | Brother HL-2030 Laser Printer
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Brother HL-2030 continually prints test pages
disconnect the printer from your pc and clear out all print jobs... leave it on and let it sit for a day... if no test page prints then the problem is your pc... if it starts printing like crazy then reset it via page 54 of the user guide if it still prints like crazy with the network cable or usb cable disconnected then you need to call brothers tech support but more than likely it shouldn't do anything... if this is the case... the problem is your pc... or your server...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 20, 2009 | Brother HL-2040 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Dec 11, 2009 | Brother HL-2030 Laser Printer
HL-2030 Continuous Paper Light Flashing.
i looked at the service manuals, there is not one for the hl-2030, however for the hl-2040 is indicates that the front cover or back cover door is open, check the back door and see if the sensor is moving freely.
May 25, 2009 | Brother HL-2030 Laser Printer
Just won't print
it sounds like the toner is running low, basically when you pull out the toner cartridge it moves the toner around on the inside and enables it to print for the time being
Jan 29, 2009 | Brother HL-2030 Laser Printer
Paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Aug 30, 2008 | Brother HL-2030 Laser Printer
Toner Light
Hi.
Its nearly what the last post states,
I have had brother help desk on the phone recently due to this problem. If you get a toner cartridge that has no numbers on it, ( brother orginal parts have huge numbers stamped on the case) then the cartridge needs resetting, this is done by simply pushing the white lever on left handside about 40 degrees forwards, its stiff so give it a proper hard shove. No srews etc to undo.
Hey presto your light will go out.
Cheers
JPW
Jun 09, 2008 | Brother HL-2030 Laser Printer
BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Sep 13, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
