I have a whirlpool 2 speed, 6 cycle heavy duty top load washer. when started the water fills but will not stop but washer continues through all cycles. What causes this thanks ps can't find the model number so if someone can point me in the right direction i will get it thanks
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
We just purchased a used Kenmore Elite 42832 from a divorced couple that was unable to produce an...
(More)
We just purchased a used Kenmore Elite 42832 from a divorced couple that was unable to produce an owners manual. Can you help? Steve & Deb
my computer CPU shutdown automatically i even not turn it off...when i attemp to change the harddisk...
(More)
my computer CPU shutdown automatically i even not turn it off...when i attemp to change the harddisk of it to my other computer a error been detected reboot file not detected. whould i may retrieve my files in my harddisk
washing machine has stopped. Power lights is flashing. Code on front of machine reads 1.16. When...
(More)
washing machine has stopped. Power lights is flashing. Code on front of machine reads 1.16. When anyother button is pressed code of 'ERR' shows for about 2 seconds.
