Back to:
Tags:
Tecnik TKC8525 Double Oven
Main Oven Issue?? (by 3 users)
posted by RICHM on Dec 03, 2007
Problem started with the clock. Unable to set the time correctly due to the A in the top left corner constantly being displayed.
Now because of this unable to turn on main oven, unless you use the timer .
Any ideas ??
Comment by RICHM, posted on Sep 22, 2008
Tried all of the suggested solutions - no good...
It's as if the three main buttons are n't working at all ??
Can you get the panel off to see if there's anything loose ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Frichie, posted on Mar 10, 2008
Same problem, the main oven/fan stopped working halfway through cooking a whole bunch of pizzas. Dunno if someone maybe pressed the wrong button, but we have this A flashing in the corner, if you press the timer button it goes to the timer set, but the plus and minus buttons dont do anything. The manual mentions that if the oven is set on automatic cooking, then the manuel oven wont work. The solution is supposed to be pressing the auto cook on and off buttons together, but nothing happens when we try this.
Have tried to switch the unit on and off at the power, but the clock just reboots with the flashing A.
Any advice, or do i need to get a Technitian out
Comment by Guest, posted on Dec 23, 2007
Cannot turn clock off! Grill works Fan in oven comes on but no heat
Solution #1
posted on Sep 15, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Holding the autocook on and off buttons togther (2nd and 3rd button from left) meant the A and flashing turned off and now the bottom over works!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Main Oven Issue??:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rating: 0%, 0 votes
Thank you so much! Holding the two (autocook on and off) buttons together got rid of the A and now the bottom oven works! Great!
Thank You!
Solution #3
posted on Feb 11, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
the clock need to be set to work the main oven
Thank You!
Can you Help with these Ovens problems?
Ovens
My mother has a sunbeam fireplace. The lights come on but...
Ovens
The locking lever will not move to the clean function when...
Ovens
Started cleaning yesterday at 9am was supposed to be 3hrs...
we just moved in and there are no instruction of how to...
The appliance makes a lot of noise ( like a noisy fan )...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
