Question about Intel SuperMicro SUPER Motherboard - 810 (370SEAO)
P4sxq won't boot
When I try to boot my system I am getting one long beep...I can't find a beep code for what that might be. Any ideas?
This RAM problem
Posted on Dec 03, 2007
SOURCE:
My laptop starts but won't display. I hear loud beeps during this process, what could be the problem?
What are the beeps as they are the clue to the problem. Count the beeps.
May 12, 2016 | HP 650 Notebook PC
I have a Toshiba L675-S7013, it powers on but won't boot.
I think so, because when it tries to post aznd finds no ram you will get beep code
Jan 30, 2013 | Computers & Internet
Biostar P4SXQ has an Audio problems, everything checked including 2 jumpers on audi pins and enabled in Bios, Yellow exclamation in Device Manager, Error Code 10
Hello
I would statr with uninstalling the audio drivers then reinstalling them.
Possible you may need to install the chipset drivers first.Then the audio drivers.
Mar 11, 2011 | Biostar P4SXQ Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
My computer at start up beeps 3 times and won`t boot
Try booting up in safe mode. Press power on button and press F8 until you see a list appear. Go in under safe mode and see what the problem is....Hope this helps....
Nov 17, 2009 | Microsoft Windows XP Professional With...
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
Does it support intel & amd?
Hi aventae, the P4SXQ motherboard will only support Intel Pentium 4 or Intel Celeron processors 400MHz CPU's.
Biostar's link for the P4SXQ MB.
http://www.biostar-usa.com/mbdetails.asp?model=P4SXQ
Mike
Jul 28, 2008 | Biostar P4SXQ Motherboard
Computers & Internet Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
