Question about Disney Ramone DVD Player
Parental control my child's ramone dvd player wont play curios George. Every time i go to put it in it takes me to the parental control setting asking me to enter my 4 digit code, problem is i did not set one and i don't have the user manual so that i can set one. i looked on the net for a manual and i cant find one .If anyone has a manual or can tell me how to go about getting one i will be grateful.
  • Anonymous Dec 31, 2007
    every time I try to let my child watch a movie like E.T it wants a parental code but I did not set one
  • Anonymous Dec 22, 2008
    I have the same problem. DVD is asking for a code for parental control. I put in 1234,it did not work for me.
My son's cars ramone dvd player did the same thing too. I put in 1234 and then ok and the movie started to play.
Posted on Dec 28, 2007
2 Suggested Answers
SOURCE:
SOURCE: I need manual for disney ramone dvd player
1369 is the code to allow you to play blocked movies although I still haven't found a way to change the level. You have to input the code each time.
Posted on Dec 18, 2007
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Asking for pin number
How do you change/reset the pin code of Child Lock/Parental Control settings?
  1. In disc mode, press SYSTEM MENU.
  2. Press 060414114420_12548.gif to select Preference.
  3. Press OK to confirm.
  4. Press 060414114406_12547.gif to highlight PASSWORD, then press 060414114432_12549.gif to select CHANGE.
  5. Use the numeric keypad (0-9) to enter your old six-digit password.
    • When doing this for the first time, key in 136900.
    • If you forget your old six-digit password, key in 136900.
  6. Enter the new six-digit password.
  7. Enter the new six-digit password a second time to confirm. The new six-digit password will now take effect.
  8. Press OK to confirm.
Apr 13, 2013 | Philips DVP3020 DVD Player
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
My child accidentally put a parental code and how can i reset the ps2
Mar 26, 2010 | Sony PlayStation 2 (PS2) Console
The parental lock is on and I don't know the four digit password
My husband was playing with our remote and accidently put parental lock on. We could play cd's but not dvd's. Here is what I did. Go to the set up menu. Arrow over to the parental control and press enter. Arrow down to where to put your password in. Enter 0000 this is the factory default code. It will ask you to enter it again. then return to the main menu. I turned mine off with the remote then turned it back on, put a dvd in and it worked. My husband was ready to go buy a new dvd player. Power to the women!!! Hope it helps you.
Sep 01, 2008 | GE1401P DVD Player
DVD player parent lock
My unlock code is 0123, I didn't set it but it works to unlock parental controls
Mar 28, 2008 | Disney Televison & Video
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Sep 24, 2007 | Disney Ramone DVD Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Disney Ramone DVD Player Logo
268 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Dalynn Turner
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
