Question about Navman PiN 570 GPS Receiver
Cant get the menu display on my pin 570
Hi, when iI turn on the pda all I get is the windows screen then the align screen . I tap the screen and the + moves to each corner of the screen then to the centre.
I have all the software installed in the pda or so my desktop tells me , Can you help.... I'm only new to this concept... Craig
    Problem Solver:
  • 12 Answers
Maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Posted on Mar 30, 2008
fix:
Hi i have accidently deleted the voice navigation from my navman 550 sat nav and cant get it back ihave tried reset can you help
Is it Possible you have turned off the volume?
Here is how to check the volume setting:
From the Main Menu screen, tap Preferences.
The Preferences screen will display.
2. From the Preferences screen, tap More Preferences.
The second Preferences screen will display.
3. On the second Preferences screen, tap Hardware.
The Hardware screen will display.
4. From the Hardware screen, tap Volume.
The Volume screen will display.
5. To increase volume, move the Volume Level slider towards High; to decrease volume,
move the Volume Level slider towards Low.
• Tap Test to test the volume.
6. Tap Save.
The Main Menu screen will display.
Jun 06, 2011 | GPS
Broken lcd on Pin 570
The screen is expensive in relation to the value of the pda so a practical solution is to buy a donor pda with a different fault being offered cheaply for spares. The screen is the same as that for the Acer N35. Both PDA's are based on the same motherboard although they are not interchangeable due to slightly different fittings for example the GPS aerial connector. Screens and batteries are interchangeable.Try Ebay or Trade Me. If the ribbon is not pushed home firmly and square before locking in, it will not work and swicth on and off and on to check. You need a certain amount of good fortune when buying a dead donor as any other fault may disguise the fact that the donor's screen may also be kaput!
Jun 20, 2009 | Navman PiN 570 GPS Receiver
The align keeps on and on
You should align your screen by tapping each time (Just tap a bit carefully and with a little bit more pressure) that cross shows up during the setup process. It should take 4-5 steps and at the end you can follow the other setup instructions. Hope this helps.
May 17, 2009 | O2 Xda II mini
Backlight not working on my Navman Pin 570
On the main menu (Start-- Win Logo) go to settings. Then go to system at the bottom of the screen. Tap on Power. At the very bottom of the screen in small print go to "Adjust Backlight settings to conserve power". Click on "backlight" in blue print.
Apr 16, 2009 | Navman PiN 570 GPS Receiver
I cant get past the align screen on my o2
When you don't charge your PDA's battery for a while, and let both normal and backup batteries to finish completely, all your data in your PDA is lost, and it will go back to factory default state. As the operating system is stored in the ROM of your PDA, it will be reinstalled when you charge it again, and becuase there's no data left from the past state, you have to do all the settings again from the start, beginning with the screen alignment (You can tap carefully on the plus sign each time it moves). If you had a backup syncronized with your PC, you can then recover your data to your PDA.
Apr 09, 2009 | O2 Xda II mini
Mitac Mio DigiWalker 168, Pocket PC PDA w/ GPS
mijn probleem is dat ik deze pc/pda in het nederlands wil zetten hoe doe ik dat
Sep 09, 2008 | Mitac Mio 168RS GPS Receiver
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
Align screen problem
plz plz plz help my problem with O2 XDMini s wen i torn on is say windows mobile tap the screen to set up your windows mobile-based device then wen i toch the screen crosor coming up its like thes all the time plz plz if anyone can help moha.5838@hotmail.com thanks
Feb 08, 2008 | O2 Xda II mini
Screen tapping is not working
have u tried "screen alignment" menu for configuration
Jul 08, 2007 | O2 Xda II mini
Not responding......help
Low or flat battery. Connect to mains charger and fully charge.
May 27, 2007 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
103 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
