hot water dripping if I open midway, runs through all cycles but dishes are not clean (especially on top) and soap dispenser is open but only partailly gone when finished.....
kenmore 655.13222 k601 bought 5 months ago after insalation machine stops and clean light comes on...
(More)
kenmore 655.13222 k601 bought 5 months ago after insalation machine stops and clean light comes on flashing. had a repair man in changed circut board. month later of same issues told us the drain was not connected properly. today had a service man in and a wire was off to the element. now it runs a full cycle. what i would like to know is how long should all the cycles be if set to normal or fast etc. and when heated dry is selected should dished be fully dry . cause on normal - with heated dry turned on - everything is still wet like machine just turned off nore do the modes on the dishwasher change ie light stays on for normal clean but never lights up at rinse or drying just normal to clean? any one any ideas?
It leaks out of the float switch, occasionally. I think it comes from the float switch because it...
(More)
It leaks out of the float switch, occasionally. I think it comes from the float switch because it drips off the bottom of the switch. When it leaks the amounts vary from hardly any to a cup.
