'95 Chevy Blazer driver's sit wire doen't have power I check with a multimeter and no volts, I tried with a electric cord and the sit works
The wires between the door and frame are probobly broken from opening and closing so much....run into it a lot...cheap fix is to cut the rubber boot off with a razor knife and splice in a piece of wire....tight working in there and make sure you seal them up with heat shrink and lots of electrical tape,,,good luck...Lee
You will have to check the switch for input power,to see if the switch itself is getting power.If so,then the switch would be bad.The switch works on a reverse polarity pattern.So you can`t replace it very well with a normal off and on switch.So you will have to get a switch like it.If the switch is good,and your sure,is there power to the switch?If not check for a breaker to be bad(in the fuse box).If there is not a breaker,follow the main power wire from the switch until you find the power source.Most likely a relay or two,and a fusible link that is burned up,just replace them as needed.
