Pc restarting. my pc keeps on restarting after logon. it stays on for about a minute or two, then it just restarts. i restarted in safe mode. done a restore point. did not fix my problem.
  • tutulbd Dec 11, 2008
    I have the similar problem but it's little different. I got blue screen on(winxp sp3) but pc reboot so fast that i can't read the error code.
    but when installed windows vista ultimate 32bit. i don't get any problem like this.
    I am using Pentium Dual core E2200 2.2 Ghz CPU, Intel DG31PR Main board, Transcend DDR2 800 1GB*2= 2GB RAM with samsung 250gb HDD. Can any one help me out.
    Brigadier General:
  • 6,966 Answers
If your PC (and I will assume a desktop) restarts without going into a dump or blue screen of death (BSOD), it is possible that you have a hardware fault. The possibilities could be:
1. defective capacitors near the CPU.They should be visually checked for any swelling, dielectric leakage or anything out of the ordinary. If the top is bulging, then they have overheated;
2. defective/underrated power supply; and/or
3. defective (or slow) CPU fan (or sometimes that of the video card).
In some instances, some virus have been known to cause a forced restart.
Hope this be of some help/idea. Pls post back with brand/model of your PC/motherboard or should you need additional information.
Good luck and kind regards.
Posted on Dec 03, 2007
SOURCE:
When i installed my olympus camera software i received the message "hardware malfunction call your hardware vendor for support" and now my pc will not boot
Please restart your pc, and keep hitting the F8 key as soon as you restart. You should get an advanced options screen. Choose Safe Mode with Networking and wait for the files to load. After 10 minutes you should be on your desktop. If your pc successfully restarts in safe mode then uninstall the olympus software from the add/remove programs and restart your pc again. This time don't press anything and wait for the pc to start normally.
Hope that helps!
Sep 06, 2011 | Dell Dimension 2400 PC Desktop
Every time I use my password I get kick out how do I create a new one?
1. restart your laptop 2. press F5 or F8 during boot (to display boot option) 3. select 'safe mode' from list 4. open your computer as administrator in logon screen (not your own user account) 5. go to control panel 6. select user accounts 7. create a new account 8. and restart your pc and open your computer as your wish HEHEHEHEHEH
You can save your files from previous account . to do this :- 1. create a new account by safe mode... 2. select your previous account it and click on delete 3. click on keep files....
THANK YOU DEAR
Aug 13, 2011 | Computers & Internet
Keep restarting every 5-10mins. was inf motherboard bad
Restarting loop in your computer can be caused various reasons.
1. Overheating of the processor.
2. Problem with your operating system
3. Motherboard failures
While restarting your computer you should be seeing the Sony logo and then the windows logo, post which you will go to your desktop background. If your computer is restarting immediately after the windows logo before loading windows desktop, then the problem can also be with the windows operating system. For this situation while your computer is restarting keep tapping the F8 key as soon as you see the sony logo, then choose safe mode and hit enter, This should load safe mode, in safe mode wait for some time and see if your computer is restarting. if not then the issue is with some recently made change or recently installed software or hardware. If it restarts even from safe then the issue is with the hardware of your computer
Mar 05, 2011 | Sony VAIO VGN-CS110E/Q Widescreen Notebook...
Toshiba Satellite M35X-S311 PC Notebook restarts by itself
If you can start it up on safe mode go and back up the files that you needed because formatting the HD will be needed and reinstalling the operating system. You can also download malwarebytes first and run it during safe mode. once it is finish restart it in normal mode if it does not work perform the 1st step above.
Apr 06, 2010 | Toshiba Satellite M35X-S311 Notebook
Logon screen will not accept any passwords.
hi,follow these steps :
1.turn it on
2.press F8
3.select safe mode or safe mode with networking if you need internet
4.here you can save,change ,delete accounts so on
5.when you done restart and you can log on with your settings.
Jan 09, 2010 | Dell Inspiron 8100 Notebook
Power problem with HP Compaq d530 Convertible Minitower Desktop
Try this first : Load the bios (F10 - vista or F1 - XP), Load setup defaults F5. then Save changes F10, and try restarting your pc.
Secondly, after restarting your pc, on the HP invent screen, keep tapping on F9 for the diagnostic test
If theres no any error message, press any other key ACCEPT for the 'R' key to restart or repeat the test.
Other sollution ----------------------
Try loading into safe mode F8, select on the safe mode and let the computer stays into safe mode for sometime.
If the pc doesnt restart, it means theres no any HW problem in ur pc. If it does the same, it means, you will need to check your Power supply, M/board with your tech
Jun 20, 2009 | Compaq Computers & Internet
L350-170 Logon Failure
Sounds like profile corruption or virus problem. Try restarting the machine and tapping f8 until menu appears. Go into safe mode then logon as administrator. If you can get into windows, go to control panel then user accounts. Create new user account then restart machine. Log on using new user account and copy all personal files/folders to new user account.
Apr 08, 2009 | Toshiba Satellite M45-S2652 Notebook
Pc restarts at logon screen
You could try chkdsk /r at the prompt in safe mode?
Feb 16, 2009 | E-Machines eMachines Desktop PC
T1100 emachine - restarts at windows logon screen
Have you made any hardware/software changes lately? If answer is no, reboot the pc and hit F8 a couple times. This will give you a list of options. Use your arrows and highlight last known good configuration and hit enter. See if your pc boots ok. If you don't have that option or it doesn't boot ok, Repeat the process to get the list. Use the arrow keys to higlight Safe Mode and hit enter. Your pc should boot to safe mode. Click on Start>progams>accessories>system tools>system restore. Choose a safe date about 3 days ago and do a restore. Wait until it's done completely! and see if it's working ok. If this fixed your problem please rate as fixed. If you need more help with this just add a comment and I'll be glad to help out. Thanks.
Apr 11, 2008 | Computers & Internet
Acer Keeps restarting
You have to reinstall your operating system. There is no other option. Bcoz every time the operating system try to operate hardware it receive wrong info from the hardware drivers. Contact me again for more info
Mar 31, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
582 people viewed this question
Ekse
Alun Cox
