Question about HP 9200C Digital Sender
Processing digital send job
My Hp9200c sometimes makes me crazy
Scan to Email is working fine all the times
buth there is a problem with scan to folder
the control panel displays (processing digital send job) and the scanned file doesn't reach the scanned folder also the Data LED keeps blinking.
I tried my best to sort out this issue. I uninstalled the Hp software and reinstalled it back, for few dayz things were working fine but after few days it is back on the same track.
The scan folder location is on another server. so, I deleted it and created on the same server where the digital sender software is installed and configured, but nothing works out and the problem remains the same.
sometimes it starts working on its own without any restarts.
Please help me out of this
any help in this regard will be highly appreciated
thanks in anticipation
SOURCE:
SOURCE: Scanner wont scan
please you change warming lamp strip.
Posted on Jan 07, 2008
SOURCE: Hp5590 Front Panel Scan buttons does not work
thsi is it
Posted on Nov 03, 2008
SOURCE: Can't install my HP Scanjet 3970!
Billy,unplug the scanner.go into device manager and remove/uninstall all drivers for the scan jet.reboot computer.go to hp site and download new drivers/set-up.reboot computer.hook scanner back up to pc.pc shuld see the device and load drivers .if not go back into device manager and find/click on scanner.tell it to update drivers it shout do this automaticly..but if not point it to the new drivers.update.if you still having a problem or i have confused you contact me here.RICHARDM69
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: HP Scanjet 5590 nothing showing in Scan to box
go to control panel and start using the scanner from their it may work
Posted on Jan 12, 2009
SOURCE: cannot uninstall or install HP scanjet G2410
I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
Posted on Aug 09, 2009
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
May 17, 2013 | Canon imageRUNNER 3225 Black and White...
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
I can't find any instructions how to scan documents so I can store them on the PC and e-mail them.
here the manual http://www.manualservice.net/guide/free-pdf-manual-for-mp540/page/11
Apr 18, 2011 | Canon PIXMA MP540 All-In-One InkJet...
I inherited a Brother MFC-440CN printer with no instructions. How can I scan a document from the printer to my email?
just scan it using the command from the computer ..after that you will find the job into the manager folder..of the scanner..from there you can send it directly ..or edit a little ..and copy into computer and attach to the email..or ..use the feature from the scanner's program to send it ..
make sure you set to scan picture cause scanners have a wizard that you can set to scan image (picture Jpeg ....) or PDF ..document ..
May 18, 2010 | Brother MultiFunction Center MFC-440CN...
How do i scan to my email? I have a brother product MFC-290c all in one with fax and i am trying ro scan to a picture to my email
May 14, 2010 | Brother MFC-290C Printer
How does the 1210 scanner work with Windows 7? I have downloaded the driver for the printer and it works ok, but I cannot use the software for the printer. The copier and the scanner work, but i cannot...
You will have to do a two step process to send a scanned document or image by email; the scan to e-mail button won't work. Scan using either Windows Fax and Scan or Paint. Save your file. Then start (Compose/Write) an e-mail to the person you need to send the document. Click Attach and browse to the location where the scan was saved. The default folder is C:/Users/<user_name>/My Documents/Scanned Documents . Click OK after selecting that image. Finish writing your e-mail and send it.
If you'd like to automatically open the e-mail program, browse to the folder where you saved the fax from Computer (Start button) and right click on the image. Choose Send to Mail Recipient. The new mail compose window should open.
I hope this helps.
(a program like PaperPort may let you send to e-mail recipient without the extra step; however I'm not sure of the details.)
Mar 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
Scan job returns error job is done improperly. Check log 6385
I had this problem when sending to mail account.
This can also be changed for ftp/smb.
So maby this is the answer to you problem.
Solution: Extend the time-out from 90 to 300 seconds
Goto the setting of the machine (http://<ip>) and login with Administrator account.
On the page Network click on Email/SMTP.
Change the Time-Out setting to 300 seconds.
Good Luck!
Greets,
Ivan
Jan 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Unable to scan b/w neg's correctly using Digital ICE
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Jan 16, 2009 | Nikon CoolScan V ED Film Scanner
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
HP 9200C Digital Sender Logo
629 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
