Question about LG DU-42PY10 42 in. Plasma HDTV
Red/pink shades in dark areas happens only 6ins down from top
I have a LG DU-42PY10 42in and owned it for about 3 years now. After a couple of hours of watching TV, the top area of the screen about 6in down from the top turns red/pink shades in some pictures. Then I turn off the TV for about 10mins and it goes away. How do I fix this? Somebody help please!!
I also have 1 pixel that flickers red off and on.
  • veils Dec 04, 2007
    Thank you for your help, but where is the ic or cap located? Also is this the same as the red sparkeling problem?
MY LG DU-42PY10 JUST DROPT AND THE SCREEN INSIDE IS BROKEN NOT OUTSIDE IT SHOWS ME DIFFRENT COLOUR LIKE BLACK GREEN WHITE AND IS JUST A YEAR OLD PLS WAT CAN I DO THANKS
Posted on May 30, 2008
    President:
  • 4,402 Answers
Sounds like you have a cap that leaky or a ic thats getting hot,
if you want to try and fix it yourself get a can of freeze it
http://www.chemtronics.com/products/product.asp?id=78
and when the problem appears spray the can on each (ic or cap) part till the problem goes away.
Posted on Dec 04, 2007
  • Cary Farah
    Cary Farah Dec 04, 2007
    don't know that why you spray one at a time and when it disappears you found it. it will most likely have a heat sink on it or if you touch it it might be hot but be careful theres high voltage inside there.
    I have no clue on the sparkly sorry
I'm having the same problems, in the dark areas i get a red shade. has lg or anyone else figured out how to fix it, if so your help would be appreciated very much. also i have my pc connected to it and having the same problems.
KOne
Posted on Jun 16, 2008
SOURCE:
LG 55LH90-UB LED TV I have an LG 55LH90-UB LED tv that has, what seems to be, sections of dim areas.
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
good luck buddy
May 18, 2017 | LG Televison & Video
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-37LZ30 goes blank on it's own...
This is a bad digital main board. Having to unplug and plug it back in is a dead giveaway for this problem. The part number for the main digital board is 3313TD3014A. Hope this helps.
Dec 26, 2008 | LG 32LX1D 32 in. LCD Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
[email protected]
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
May 24, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-42PY10 42 in. Plasma HDTV Logo
492 people viewed this question
Ekse
