AKAI TELEVISION WHEN YOU SWITCH ON - NO PICTURE, NO SUND - BLUE SCREEN.AFTER 10 TO 15 MINUTES, IT COMES ON, EVERYTHING WORKS.YOU CAN PLAY DVD'S - NO PROBLEM - IMMMEDIATE PICTURE. MODEL: AKAI CT-T29S33A 74CM COLOUR TV
  • Anonymous Mar 22, 2014
    blur picture
    Genius:
  • 1,694 Answers
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Posted on Dec 03, 2007
SOURCE:
Flat screen TV only has volume. When we turn it on, the screen is light gray with a darker gray stripe in the middle. TV is only three years old! The dvd which is part of the TV stopped working in the...
Sunds like a tv issue. I would try to connect a dvd player or vcr to it to see if that works to eliminate the service provider first, if it still doesnt work its the tv.
Nov 20, 2010 | Akai Televison & Video
T.V. COMES ON WITH A BLUE SCREEN ONLY WILL ONLY PLAY DVD'S
CHECK TO SEE IF YOU TV IS SET TO AV OR EXT 1 OR 2 ETC
IN SET UP MENU OF YOUR TV
CHECK SCART PLUGS ARE PROPERLY INSERTED
Aug 25, 2010 | Protron PLTV-37 37 in. LCD Television
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Blue screen
Did you see the back light at the back. If yes, the problem may come from T-Con board. Try other source like playing DVD AND If THE SAME PROBLEM HAPPEN, you may think of the main board defective.
Aug 15, 2009 | Samsung Televison & Video
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Can't get anything on the screen
Unplug the power cord from the TV set and leave it unplugged for 5 minutes. Plug the power cord back into the TV and turn it on. It should work. This is not an uncommon problem for the Akai line.
Nov 02, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
AKAI Rear projection TV
Try using different inputs besides the RF input. Connect your PS2 and DVD player using component inputs. With two component inputs, there's no reason in the world not to do this.
Feb 28, 2008 | Akai PT4298HD Rear Projection Television
Akai large screen T.V. color problems
I have a similar problem with my AKAI 42 inch plasma, now my whole tv is purple. all you can do is contact akai warranty and have a service provider come out. but let me tell you, it is not an easy process if the service provider cannot help you. after the service provider told me that my tv was a goner. it took me two months to get a box to then send the tv back to an akai service center. now i have to wait a month or so, before i get it back. i wish you good luck.
Feb 26, 2008 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Ekse
