Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
No power Green light is not on to indicate power. I had transfered at least 400 GB yesterday and I can not turn on the unit. Is this broken?
  • 1 more comment
  • frylira Dec 03, 2007
    No power...had it working
  • Mbree Dec 03, 2007
    I had mine running for a 'test' backup with 100+GB of data. I came down in the morning and it was not powered on. Tried a reboot and another PC, and nothing...no power. I happen to have a power supply on an other external drive that was the same output (12V 2A positive polarity) and the drive magically came back. The power supplies are suspect on these at best. WD is sending me a new one. I will see if the new one can last and hope I just got a lemon of a power supply. Let's hope they don't have supplier issue with the cheap feeling power supplies.
  • philsharque Dec 07, 2007
    I got the some problem!!
    Problem Solver:
  • 5 Answers
Well try laving the power of the drive for about a day so the device can reset. Before using it again turn off the computer and plug the hard drive into the computer and then turn everything on at the same time. If nothing that please post for more help.
Posted on Dec 04, 2007
I have a Canon Image Class 8580 CDW with Error E070-0000 Changed the Fuser could it be the Transfer ?
Dear
The code due to, ITB/TOP sensor defect, DC controller PCB defect.
Do the procedure to check yourself.
1. Turn off the printer.
2. Hold down the Resume / Cancel Press the POWER - indicator turns green.
3. Release the Resume / Cancel, still holding the POWER.
4. Press the Resume / Cancel 2 times while holding POWER, then release all buttons.
5. When the indicator light remains green - press the Resume / Cancel 4 times.
6. Turn off the printer button POWER. Then turn, this should solve the problem.
If the problem not clear, take the help of trained service engineer to check the connector of the ITB unit, DC controller PCB. • Replace ITB unit • Replace DC controller PCB.
Thanks.
Jan 31, 2015 | Canon imageCLASS Office Equipment &...
Why is the green light going on and off on my senaphone modle 400?
I'm assuming this is the System On LED on the Sensaphone 400. That would indicate that the unit is in standby mode. All you will need to do is Press the [Run/Standby] key this will turn the Sensaphone back On. The system On LED on the Sensaphone 400 & 800 flash when the device is in standby mode, solid lit when the device is On. If these units are in standby, they do not recognize alarms nor do they pick up the phone on a dial in.
Here is a link to the manual if needed
Support Sensaphone 400 Monitoring System
Jul 28, 2014 | Sensaphone Alarm Monitor - Model 400 -...
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Doesn't spin & Power light flashes red to green
This situation indicates a problem with the built-in self tests. Most likely a power supply failure. I don't believe it is economically feasible to replace the power supply. If it is still under warranty, I'd go through the procedure to get it repaired/replaced. Otherwise, you'll need to replace the unit.
Dec 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Apr 07, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
67 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
