Question about IBM ThinkPad T20 2647 Notebook
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
My friends computer wont show anything but a black screen after it shows toshiba line saying press something like f2 for the bios and f12 for boot but it wont go to the boot it just stays on a black screen. then after it sat for awhile it said to reinstall windows xp something and when we hit enter it didn't do anything just stayed on the black screen .
can anyone please help him
    New Friend:
  • 10 Answers
1. Go to this website and download Ultimate Boot CD
2. Now download this tool to burn this Image
toshiba satellite with windows xp will only show b - 1_22_2013_10_27_28_pm.jpg
This is the program you should have downloaded.
Now that you have the program where it says file location look for the location you downloaded your file. Usually its C:\Downloads but it could be in a different location. Once you've located the file burn it to a CD or DVD of your choice.
4. Once you boot this cd you need to look for Partition Manager click on it. Click on HDD and then look for FDISK.
Make sure that you have an active partition which should say C: Active
Posted on Jan 22, 2013
  • Michael Trevino Jan 24, 2013
    http://www.hiren.info/pages/bootcd You can also try this boot cd it's an all in one packaged solution for any repair needs.
    Master:
    Sergeant:
  • 482 Answers
Could be a virus. try f2, bois have it read the hard disk, save. if you upgraded the bois try to take it out, and make sure its reads as the same as the other chip.
Posted on Dec 03, 2007
SOURCE:
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
Will not load windows,installs all of the files, but a blue screen appears, with error codes
I had the same issue with my Toshiba Sattelite L305 and I had to send to Toshiba to repair, hopefully your is under warranty
Dec 10, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite L25-s1194 wont boot windows
Is it giving you any error or out of the ordinary "beeping" as it is booting?
Usually the BIOS screen comes up if it cannot find an acceptable boot device.
Can you boot from an XP cd?
Can you boot into set up mode.. usually by pressing F1 or F2 on most computers. It should tell you just before the BIOS screen comes up. Enter into "set up" and make sure your boot order is correct.
You might want to reseat your RAM.
Check to see if the hard drive is coming on.
Nov 21, 2009 | Computers & Internet
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satelite M100 PC notebook wont start up windows XP
This sounds like a memory problem. Download and run memtest 86, it is a small iso file that you create a bootable cd from. Run this for at least one pass.
If the memory passes boot from your xp disk and choose R to get into the repair console. Once there type the following commands
fixboot
fixmbr
then try the install again. Hope this helps
Apr 29, 2009 | Toshiba Satellite M100 Notebook
My laptop is a Toshiba satellite and after i login a black screen
Hi there. If you've had the laptop under a year, then you can take it back to the place where you bought it, and they can take a look. If anything's wrong, then it can be fixed under the manufacturer's warranty, which is normally for 12 months from purchase.
One thing I'd like to ask, can you see anything behind the black screen? I ask this, as I had a friend who had similar problem, but it was a faint black, with the cursor flashing, and he could faintly see the desktop in the background. I was wondering if this was the same for you.
Apr 13, 2009 | Toshiba Satellite A135-S2276 Notebook
Monitor went black
Try reinstalling the Display
driver
Mar 31, 2009 | Computers & Internet
Computer problem
may be u have problem with the display driver or u have a corrupted windows xp try to run the windows in "ENABLE VGA MODE" if it works fine then just reset the display settings else u have to try to repair / reinstall winxp
mai me ur response @ [email protected]
May 01, 2008 | Compaq Evo N610C Notebook
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
IBM ThinkPad T20 2647 Notebook Logo
198 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
