Question about SanDisk Sansa c150 MP3 Player
I cant connect my Sandisk sansac150 to my computer. When its conneting its showing 'Start update browser DB' then again ' Sandisk' again ''Start update browser DB' like that.. I cant see that in my system now
  • TLO421 Dec 16, 2007
    yeah mines the same... when turned on it just shows the sandisk welcome thing then after a little while Start Update BrowserDB comes up.... hard reset doesnt work which is like the only solution ive found so far...
My dear frd... i cant see its menu itself... its showing only welcome screen and the browser db update .. wht to do ..
Posted on Dec 23, 2007
    Problem Solver:
  • 19 Answers
I haven't run into this problem but try this, it might help...
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Hope this helps!
SOURCE:
Sansa e260 says cannpt load image switch to recovery mode
download the update software and install then.. lock your sansa, hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer... Download the sansa update software
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
You may need to make sure you are connected to a 2.0 USB port if your computer is not IDing it, try a friends computer or a labtop... USB modes msc...
Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate...
Jun 06, 2009 | SanDisk Sansa e260 MP3 Player
Battery won't recharge on my sandisk clip anymore
my c140 mp3 player conect to the computer and then auto re start again & agin
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
CANT FREE UP ANY SPACE ON MY SANDISK
The only thing to do for this error is goto My Computer/Computer and right click on the Sansa player, choose format.  Select Quick format.  It will delete all data but at least the player will work again.
Jan 24, 2009 | SanDisk Sansa Fuze MP3 Player
"Not enough space for Music DB. Please Free 4MB"
Corrupt database - upgrade the firmware from www.sandisk.com
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 31, 2008 | SanDisk Sansa m250 MP3 Player
Stuck in Sandisk image
Go to the Sansa website, and get the Sansa recovery tool:
http://www.sandisk.com/Retail/DriverDownloads.asp
Go ahead and do this, in case you have Windows Media Player 11 or the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 06, 2008 | SanDisk Sansa E280 MP3 Player
Sansa 1 gig mp3
Go ahead and do this, in case the DB is corrupted:
Dec 29, 2007 | SanDisk Sansa e250 MP3 Player
we had that problem and sandisk had us use a file when we plugged it in to our computer to reformat it but I don't remember how exactly how to do it, seems like we connected it and chose a file -sorry
Feb 22, 2007 | SanDisk Sansa m230 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
