Question about HP Compaq Presario V2000 Notebook
Compaq Presario V2000 How do I find or locate the reset on the mother boardrecently replaced
I recently replaced the fan in my laptop. Now I keep receiving this message when I start it up.Intel UNDlcopyright (C) 1997-2000 Intel Corporation
For Realtek RTL8139(X)/8130/810X PCI fast Ethernel Controler V2.13(020326) PXE-E61:Media test failture, check cable PXL-MOF: Exiting PXE ROM
someone replied that I needed to reset something on the mother board but I don't know how to identify the nother board. Does anyone have a diagram or something that will help me.
Thanks
sandra1946
  • 2 more comments
  • Anonymous Dec 04, 2007
    KEYBORD
  • primetimecl Jan 11, 2008
    I'm getting the exact same message and can't get anything to work...
  • DANGABE14 Jul 31, 2008
    I HAD A PROBLEM WITH MY COMPAQ PRESARIO V200 ASKING FOR A PASSWORD I PULLED OUT THE BIOS BATTERY THAT SOLVED THIS PROBLEM BUT I CANT SEEM TO INSTALL AN OPERATING SYSTEM WHEN I TRY IT SEEMS TO TAKE FOREVER THEN IT SAYS DRIVE 0 HAS A DEVICE SELECT ERROR OR IT SAYS THE DISK IS BAD
  • vsellers Jan 25, 2009
    I have the same problem - stating up compaq v2000 and it begins by asking for a password. I see I can remove the Bios battery - where is it located?
  • 97 Answers
I had the same problem with my v2000. HP Online check used to come up with the model 2300 CTO! and the warning this may not be your lap top. Then how can we trust their recommendations for the update softwares?
The problem I discovered is the cd drive in my case atleast. I replaced the cmos battery.
The CD drive fits rather loosely into the mother board. There are a couple of screws which holds the drive in place. If the drive has not been placed right you get this error. Especiallybecause you have to remove these screws to take the base cover off. Whats more a loose drive like this gives all kinds of errors including so and so file corrupt, setup cannot continue, press any key to exit etc during reinstallation of xp.
Hope this helps.
Posted on Nov 10, 2008
  • 138 Answers
Its due to some changes in your laptop! If you have jus replace the fan then there should not be any changes except fan! I think your BIOS or some other hardwares are changed Plz see to that from where you have replaced the FAN! Becoz chaning fan doesnt need any other hardware to be changed! If other parts are changed then plz install all the necessary drivers!
Posted on Dec 08, 2007
SOURCE:
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Sep 19, 2012 | HP Compaq Presario 2200 Notebook
You can download the compact presario manual here: http://h10032.www1.hp.com/ctg/Manual/c00568473.pdf
All the manual found here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=500508&lang=en&
Maybe you can press "F2" to the enter the bios setting of mother board and select the optimized default setting and then press " F10" to save and exit.
Jan 04, 2008 | Compaq Presario R3000 Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 overheats at power-in plug.
Sounds like the power jack has a short and needs to be replaced.If it melted the ac adapter tip then its a ground problem in the power jack or where it connects to the mother board.
Aug 11, 2009 | Compaq Presario Notebook
My Compaq Presario v2000 laptop does not power up after pressing the power on switch. It all started whenever I hibernated it. But it worked after several attempts. Now it has become dead. Can you help?...
Generally this type of problem arises due to Battey. But in u r case it appears like a Mother Board Problem.So u better to visit nearer HP/compaq Service Station u can extende warranty for another year if ur previous extended warranty expired within 6 months...there is a provision in HP Customer Support.
Apart from this You can buy third party Mother boards compatible for V 2000 in other Laptop Acessories store
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. [email protected]
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Mother board
Here's a link to the V2000 motherboard listings at Ebay. Many of these have worldwide shipping, so you shouldn't have any problems getting a good board for your machine.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+Compaq+Presario+V2000+motherboard&category0=
Jul 29, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
940 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
