Power port failure
I am not able to use the power adapter for recharging or for a power supply, is it my power port? how do I fix this?
  • Anonymous Dec 29, 2008
    my battery will not recharge and every time i move the laptop slightly, it cuts out and i loose all power.
  • Anonymous Apr 14, 2009
    My power cord is plugged into the wall and my laptop. If I move it slightly the power might register, but if I move it too much, the whole laptop shuts down.
I had the same problem with my Presario. The power cord is a weak spot in these computers.
You probably will need to replace it. When it wiggles it looses connection and stops charging.
The plug in the wire, (closest to the computer) is usually the problem. However the plug at the wall receptical is also sometimes a problem.
Hope this helps.
Posted on May 29, 2009
    Master:
    Sergeant:
  • 482 Answers
The power box may have when bad on you, if you have tried to use it with some thing other then the laptop it will blow and you would need a new one, look on ebay, it should have the numbers on it.
Posted on Dec 03, 2007
R50e laptop
It's probably your power jack inside your laptop. It's attached to your motherboard, it's not making a connection with the cable when you plug it in.
Check out this link
Or you might have to call a local repair shop.
Dec 09, 2007 | IBM ThinkPad R50e Notebook
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
Tip
Beep Codes (Different BIOS) " What they mean "
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
Nov 04, 2014 | magicJack PLUS VOIP Phone Adapter
I have a Dell Inspiron 710m. I was running on batteries until I noticed that it was running low. I plugged my A/C adapter to recharge the battery but noticed that the pilot lamp of the adapter was not...
Seems to me like an AC adapter problem. I think your adapter output power has degraded to a point that it no longer provides enough power to run the laptop & charge the battery at the same time.
I recommend that you refer to the following article for diagnosing the problem & fixing it:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Mar 28, 2011 | Dell Computers & Internet
How do you recharge a MA933A-1PT without buying a baterry
MP3 players have a rechargeable battery. It can be recharged by plugging it into a USB port os a powered up computer. The other way is to use an mains adapter USB power supply/charger.
Feb 07, 2010 | Nextar MA933A MP3 Player
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
R50e PC Notebook Problem
And once you get the power socket (pin) repaired, get a Cable Retention Device like the video shows. . .
Computers & Internet Logo
456 people viewed this question
Alun Cox
David Payne
David Payne
