Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon Multipass MP700
My windows xp won't detect my scanner. The printer works fine. I've reinstalled the driver from the internet, since I no longer have the disk, and still doesn't detect it.
When trying to print color documents or photos using our Canon MultiPASS 700, the photo or document will have stripes all the way through it. It has also developed a problem of having fine lines that do not print when we are printing a black and white document.
Posted on Jan 26, 2008
Driver Canon Multipass L60 For Xp
According to Canon the Multipass L60 is not compatible with Windows 2000 or XP.
The trick is using the Multipass 6000 driver for windows 2000. This printer is compatible with the MPL60. You need to edit the driver-inifiles (both copies of mpmaster.ini). as follows:
[Setup]
ModelName=MultiPASS L60
SGModelName=Canon MultiPASS L60
BaseName=MultiPASS
PrinterName=Canon MultiPASS L60 Printer
Version=3.01
NTonly=1
[DeviceID]
MFG=Canon
MDL=MultiPASS L60
Please rate me
Nov 19, 2010 | Canon MultiPASS L60 Laser Printer
Instructions to take out/reinstall printhead on
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=9034
Click "Support and Service" Tab
Ask question: "remove printhead" Click Search button
Click best answer. Follow the instructions.
Dec 03, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Need to install but no cd-rom
Go to this page courtesy of Canon:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=9034#DownloadDetailAct
Go down to where it says drivers and downloads and in the box that says choose your OS, go ahead and choose the operating system that you have and then download the software for your printer.
May 31, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
May 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Canon MultiPASS F60 failure to communicate
Go to this web site. In the search window in the center of the screen, type "windows xp drivers" and click on the Search button. Select the first answer that shows, and you will receive instructions for downloading and installing drivers which were developed for using the MultiPASS F60 with Windows XP SP2.
Sep 26, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
I had the same problem. My 4 year old MultiPASS MP700 started banding magenta stripes across everything I printed.
I suspected the cyan printhead was clogged because the printhead tests showed two of the cyan columns as half missing.
Canon was less than helpful. I went off of my suspicion that I needed a new printhead. I found one from an online supplier for 50 bucks...better price than a new printer! I put the new print head in and it works like new.
http://www.precisionroller.com/print-heads-for-canon-multipass-mp700/products.html
Jan 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Failure to Communicate
try re installing the drivers for this printer check all cable connections once again. did the printer work well at ur frens place? and wat os did he use??
Aug 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
240 people viewed this question
old marine
old marine
