FixYa.com
Tags:
Whirlpool Duet GHW9150P Front Load Washer
F-1 code on whirlpool
posted by lisa mae on Dec 03, 2007
f-1 code shows wont work
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 22, 2007
Not Rated (0)
FIX IT RIGHT
Rank:Guru Guru
Rating: 90%, 115 votes
take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
door wont latch shut
My door wont latch closed Answer This...
will not start
3 short beeps don't start Answer This...
whirpool wtw6300sw1
water pump will not stop... Answer This...
detergent and fabric softener...
When I add the detergent and... Answer This...
dishwasher not draining at end...
What ended up being the problem... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
