Question about Polaroid PDM-0711
Broken Door: Polaroid PDM-0711
The tab that on the spring loaded door that actuates the player is broken off. Can I purchase a new door and spring?
  • 5 more comments
  • LDSmama Dec 20, 2007
    I've got the same problem. The tab on the door is broken, so we can't play dvd's. I'd like to purchase another door, but don't know where to do this.
  • kg17 Apr 21, 2008
    My son says thwhat is wrong with my dvd player as well. How can we fix it?
  • Anonymous Sep 30, 2008
    same as everyone else
  • Anonymous Nov 15, 2008
    Same problem.
  • morenita429 Dec 15, 2008
    same problem
  • Anonymous Mar 25, 2009
    broken door
  • kurban03 Mar 25, 2009
    same broken door,
It sounds stupid, but a small piece of a q-tip stick will work just fine. It fits the little hole and you can use the door to hold it down when closed.
Posted on Jul 31, 2009
    Scholar:
  • 79 Answers
You probably cant replace the door because usually they produce a small run of these players and then create a new model and discontinue the old one very quickly. My suggestion is to look if there is a small button around the area the tab would normally go to when you close the door. If you can see this button try to find someting that would keep it pressed down. This tricks the player into thinking that the door is closed. WARNING: This button also activates the laser reading unit so you must have a dvd loaded before you press the button so you dont accidently look straight into the laser unit. IF YOU LOOK INTO THE LASER YOU CAN CAUSE PERMANENT EYE DAMAGE OR EVEN BLINDNESS.
Posted on May 01, 2008
SOURCE:
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Right rear hinge for dvd door has broken and dvd will not play. can this be fixed?
Yes it can. You will have to order the whole lid assembly. The DVD will not play untill you get a new lid bcause when its engages a switch.
Aug 19, 2010 | Polaroid Portable DVD Player PDM-0822BD
Dvd player spins but then reads no disc and also the door on the dvd player is broken.
Hi the laser lens is probly dirty or dusty clean with alcool and qtips remove all dust inside and try it
for the door nothing i can do.
if that do not work the laser is burn out sorry
i hope not
have a nice day
ho dont forgot to unplug the machine and use care for clean the lens do not apply to much pressure on it
be delicate...
Mar 13, 2010 | Polaroid PDM-0711
Player comes on but will not play, on the screen it has loading disk and then goes to no disk
That means the disk is corrupted. Please make sure that data is burnt properly to the disk.
Jul 08, 2009 | Polaroid PDM-0711
Polaroid PDM-0711 DVD Player Parental Lock
Did you check the manual for a way to reset the region lock?
Nov 19, 2007 | Polaroid PDM-0711
NEED REPAIRS ON DVD PLAYER
polaroid dvd pdm-0722 it playes but no picture if you push the button near the screen it will come on for a second but the picture is also upside down can you help thanks this player is not used that much no kids thanks
e-mail is [email protected]
Sep 02, 2007 | Polaroid PDM-0824 Portable DVD Player
Polaroid PDM-0711 Logo
261 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
