Question about Dimplex DS5598 Mid-Size Heater
Dimplex ds5598 mid size fire not working
I bought this fireplace several years back and before many moves so I don't have the booklet. When I plug it in, the heat comes on, the light inside where the logs are comes on, but the flame doesn't show. It used to, but then it would stop, and sometimes come back on, but now nothing. Help, I found the perfect place for it, but it's a no ambience piece!
  • firefreak Dec 25, 2007
    I have the exact same model. Theheater works, but no flames! I tried unscrewing the bottom 6 screws -- they release the heater unit itself, but it does not appear to move enough to get to the lightbulbs. There is only one screw on the bottom of the back panel, and I can't see a wya to remove that panel without risk of damage, and I'm pretty certain that is the way to get to the lightbulbs. I can't find my owner/operator manuals either.
    I vacuumed the heater while I was in there and it still works fine.
    Just miss my flames:-(
  • Anonymous Apr 02, 2009
    Have same problem....heat but no more flames and couldn't find the spot to replace bulb for the life of me! Will try removing legs to access through the back and hope it works out for me. I love the look of flames so it reminds my grandson not to get too close! Thanks!
To replace the light bulbs, simply (1) open the 'fake" front fireplace door (2) look at the 'log' and in the front center, you'll see a Phillips head screw (3) unscrew the phillips head screw that holds in the 'logs' (4) then you can carefully lift the logs and (voila!) you'll see that two light bulbs are below it. At that point it is a cinch to unscrew and replace them! Hope that helps...
Posted on Feb 06, 2012
  • E Lew Feb 06, 2012
    To replace the light bulbs, simply (1) open the 'fake" front fireplace door (2) look at the 'log' and in the front center, you'll see a Phillips head screw (3) unscrew the phillips head screw that holds in the 'logs' (4) then you can carefully lift the logs and (voila!) you'll see that two light bulbs are below it. At that point it is a cinch to unscrew and replace them! Hope that helps...it worked for me.
As far as getting to the bulbs, you have to unscrew the legs and then you can slide the back panel off to access the bulbs. The spinning device that creates the flames has burned out on our unit, so thanks for the link to the technical number where to call to get it ordered...hopefully.
Posted on Feb 23, 2008
Tried turning on my electric fireplace after
Hi Shirley-- Maybe your question to us was cut short-- all it said was: Tried turning on my electric fireplace after about and it wouldn't do anything"-- so we need to know 'after about what...?' Tell us more-- so we can help more-- Has the heater been dropped?- or jarred badly?-- Is the connecting cord solidn and unbroken?- Is the receptacle OK-- can you plus something else into it, and test to see if the receptacle is powered now?
Mack B
Nov 02, 2013 | Dimplex DS5598 Mid-Size Heater
Heater works but there are no longer any "flames."
The flames for most electric fireplaces are a reflection of light cast onto a rotating drum of reflective strands of tinsel. The lack of flames is likely due to a burnt out bulb. In most cases, you must remove the fireplace cover to get to the bulb.
Feb 07, 2013 | Dimplex DS5598 Mid-Size Heater
Change bulb on dimplex fire not sure of make and model
If it's a fireplace that sets inside a free standing cabinet mantle, you access the bulbs by removing the glass on the front (actually, it''s plexiglass). Then remove the logs and the glowing ember bed (It lifts out). Now you can see and have access to the bulbs to change them.
It it's wood stove look-a-like unit, you can access the bulbs by removing the rectangular panel on the back, near the bottom of the of the unit. Removal of that panel gives you access to the bulbs.
Hope this helps to answer your question.
Mar 12, 2011 | Dimplex DS5598 Mid-Size Heater
Motor ,lights, everything works fine until it runs several minutes then the heat shuts off
Please check and adjust your setting on heater. Your heater reach the set point to fast preventing it to work.
Jan 10, 2011 | Dimplex DS5598 Mid-Size Heater
My Dimplex DS5598 heater lights up and the heater works fine but the flames no longer flicker to look like real flames. Does it have a fan or something? I have the Practical User's Guide but it doesn't...
It sounds like a problem with the flame motor.
I've attached a link to the manufacturer's website. They may be able to assist you with additional information upon request.
http://www1.dimplex.com/technical.aspx
Let us know if this was helpful and Good Luck to you! :-)
Feb 25, 2010 | Dimplex DS5598 Mid-Size Heater
The heater on my dimplex fire appears to be working however i replaced dud bulbs with new bulbs, and they are not working?
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Aug 06, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Mar 07, 2009 | Dimplex DS5598 Mid-Size Heater
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex air heater
my guess is the power switch is shot.
Oct 31, 2007 | Dimplex DS5598 Mid-Size Heater
Dimplex DS5598 Mid-Size Heater Logo
477 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
David Burbee
David Burbee
Oloyede Monsuru
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
