Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp printer and scanner
We have a computer, xp, and when you scan the document in wont print all the way, hope it makes sense,
How do I E-mail a hard copy document I have using HP Officejet 6500?
well it depends on what driver you have installed for that printer .. if you only have the basic print driver installed then you will need to go to hp website and download the print and scan driver for it
for windows XP you can find the driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77757-2&lc=en&dlc=en&cc=us&os=228&product=3795314&sw_lang=
for windows 7 or Vista here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77757-2&lc=en&dlc=en&cc=us&product=3795314&sw_lang=&os=4062
But chances are you probably already have the scanner driver installed and you can usually find the scanner icon in "my computer" in winxp or in "devices and printers" in vista and 7 and by clicking that icon you can usually scan the document to a folder on your computer (i usually scan it to the desktop so its easy to find)
then you can open your email program and compose a new email message or reply to one and just make sure you click on the "Attach file" button and attach the document you just scanned to the email before clicking send....
Hope this info helps
May 15, 2011 | Computers & Internet
How do i scan documents onto my comp
It depends a bit on the software you have installed (OS, etc). If you installed the full-featured software before connecting the all-in-one to your computer, you can scan immediately from the computer. For Windows, open the HP Solution Center (by double-clicking on the icon or Start > All Programs > HP folder > HP Solution Center). Put your document to be scanned face down on the scanner glass and close the lid (ADF pages go face up, top edge first). Click the tab in the Solution Center for your HP product (if you have more than one) and click Scan Picture or Scan Document as appropriate. Set the scanner settings in the pop-up window if needed. Click Scan to start the scan. To use the buttons on the scanner, you need to set the destinations for the buttons in the HP Solution Center (Scan to destination for example) and have the HP monitor running on your computer (this listens to the buttons).
Scanners work with bi-directional communication so USB hubs, print servers or bad cables can result in the printer functions working but not the scanner.
If you install the generic OS driver (by connecting the all in one to the computer before installing the software), the printer will work but the scanner will functions will be limited (the scanner buttons will not work but other functions will depend on the OS). Windows XP can acquire scans in Paint (File > From Camera or Scanner). Windows Vista and Win7 add Windows Fax and Scan which will also acquire scans (not in all versions of Vista). Vista also can acquire scans with Windows Photo Gallery.
The printer works similarly with the Mac OS but hte names may be different.
I hope this helps.
Jun 14, 2010 | HP DeskJet F4280 All In One Printer InkJet
My USB is not recognised when I try to scan with Epson TX550W
more info os type ie. xp vista win7 and type of puter and wired or wireless printer?
Mar 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I dont know how to scan from my printer hp psc 1315. printing and copy fine. please help me
Hello, Windows XP provides a basic set of scanning drivers, also referred to as Windows Image Aquisition (WIA) drivers, which you can use as an alternative to scan a document when you cannot scan using the HP drivers. You might choose to use these scanning drivers for one of the following reasons:
  • Your product released before Windows XP and HP has not released drivers that support scanning for your product.
  • You have not installed the available HP software that includes scanning.
  • You are troubleshooting a scanning problem and trying to identify the source of the problem.
Scanning with Paint To scan a document using Paint in Windows XP , follow these steps: NOTE: Before you begin, make sure that the product is connected to your computer.
Click Start , point to All Programs , point to Accessories , and then click Paint .Click File , and then click From Scanner or Camera .Make any desired setting changes.Click Scan .
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
Have a hp f380 all in one deskjet printer with M/S Vista OS
Ofcourse, if there is any software or patch, there will be free on the HP website. However, as you have mentioned, that you are able to print, that shows that the printing software is working fine, to test the scanning part, please confirm that you are able to make a copy or not from the front panel of the printer by placing a text document on the scanner bed, close the scanner lid and then press color copy. If you are able to make a copy fine, that shows that the printer functionality is working fine.
The issue could be with the communication or with the scanning software. To check the communication between the printer and the computer, perform the following steps on the Windows XP computer or Vista computer, be sure that the printer should be connected directly to the computer via USB cable at the back side of the tower without any USB HUB, as you are using a Deksjet F380, it is a USB connectivity printer.
XP:
Follow the below steps to Scan using WIA (Windows Image acquisition)
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Vista:
1. Press Windows logo and R on the keyboard*.
It will open a small run dialog box at the bottom left corner of the screen.
2. In the Run box type WIAACMGR and press enter.
3. Follow the onscreen insturctions and complete the scanning.
If you are able to scan fine using the above steps, then it shows that there is a communnication between the printer and the computer.
Please get back to me with the exact error message you are receiving when you try to scan from the computer, as to scan from the printer you should be able to scan fine from the computer (i.e., From HP Solution Center/ HP Director). So that I can assist you in much better way.
With Regards.
Mike.
Jul 03, 2009 | HP DeskJet F380 All-In-One Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Trouble with Scanner
Hi Elizabeth,
Different post, same message :)
This is a common complaint.. Are you running Vista, by any chance? The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP Pro L7650) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP OfficeJet Pro L7650 All-in-One printer and I can not get the scanner to scan documents to my computer (I can currently print to it wirelessly) When I press the scan button on the printer, it...
Hi Elizabeth,
Hope that helps.
Chris (ziraffa)
My hp 1210v
You have not informed if the version of Operating system that is installed in the computer is XP or Vista.
The printer model HP PSC 1210 have no drivers for Vista operating system.
However, I would like to provide you the article by which you can use the basic features of print and scan.
Here is the article for Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&dlc=en&product=90770&os=2093&lang=en
If you are trying to scan using XP/2000/ME Operating system, then use the below given instructions:
Click on Start >> Control Panel >> Scanners and Cameras >> Double click on the Printer icon to run the Wizard >> Just follow onscreen instructions to scan.
However, you can also scan using the below article :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00704&cc=us&lc=en&dlc=en&product=90770
Hope the above information is usefull.
Regards,
Lawrence
May 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
