Question about Compaq Presario V4000 Notebook
Rubber feets lost
I have lost 2 out of the 4 rubber feet, both at the back... as a result i m facing leveling problems which lead to loose contact ... where can i find these rubber feet ??
If you cant get second hand ones
why not try making them yourself from apiice of robber or simular material.just cut a piece simular to the ones you allready have
this may take two or three atempts .but it will be inexpensive and quick
Posted on Dec 03, 2007
SOURCE:
I need the non-slip rubber feet for the tgt bk58t
take a sample along to a rubber retailer as they have a selection of rubbers that may do the job
Oct 04, 2016 | Targus Tgt Bk58t 58 3 Way Panhead Bubble...
Where can i get rubber feet for my singer 6012C singer
Fixya is unable to identify Singer parts sources.
Feb 19, 2018 | Sewing Machines
Loose antenna connection in radio
I could probaly help you better if you posted a picture of the back but the screws are alway concealed in battery compartments and behind stickers or rubber feet. The rubber feet are usually just pressed in but can easily be re-glued.
Jan 20, 2013 | Audio Players & Recorders
Washer is out of balance in the dpin cycle since we installed a new floating floor in our laundry room. Have tried rubber feet for levelers and sticky pads to floor, nothing seems to help.
So, is the machine level and STABLE? The final step is to tilt the machine forward on to the two front feet. This allows the rear, SELF LEVELING legs to reset. Then set the machine back on all four feet.
Sometimes the real feet get jambed and will not release unless you pry them loose. In extreme cases the rear feet damage the plastic holder that they are in...
BUT, the tilt foreward and set back on rear legs works most every time.
May 01, 2011 | Washing Machines
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. http://www.mdappliance.com/ELX-5304475129.html. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
Hi, when dryer is running it is noisy. It is level, all 4 legs are tight and have rubber feet attached. Noise continues after load is leveled and when only 1 or 2 small items are being dried. Appears to be...
You need to replace the 2 rear drum roller wheels and probably the rear drum felt seal. While you have it torn down inspect the front drum glides for wear.
This dryer is worth repairing.
Aug 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Why does my EPIC z walks during spin cycle even after I used the rubber pads? It moves from the right back corner out to the left.
Make sure that the leveling feet are secure with the jamb nut tight against the BODY of the washer. If not, the washer could walk during spin. Make sure that washer is flat level front to back and side to side with a 24" level. Just set the level on the top near the front and then on both sides as well. Adjust the feet and jamb nuts so that they are as low as possible. If washer is on a stand, remove drawer to adjust feet. Also, if on stands, washer will vibrate more due to increased height and natural flexion of stand. What kind of flooring? If ceramic tile, rubber feet may not couple to surface and provide enough friction to stay in place. I have had success with......I know it might sound stupid.....but buy a couple rubber jar opener pads and cut them into small pads. Put them under the rubber feet of stand or washer. These seem to make a better connection to the floor.
Aug 01, 2009 | Washing Machines
Replacement Feet
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Feb 18, 2008 | Rival 38601 Smart Pot 6-Quart
LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Jan 02, 2008 | Washing Machines
Compaq Presario V4000 Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
