Sharp 27K-S300 27" TV
Problem for Sharp 27K-S300 27" TV
It is plugged into the
By lmegale on Aug 21, 2009
It is plugged into the cable provider's jack. I only get one channel. I don't have a remote and the channel selector on the TV does not go thru all the channels. It only gets channel 3, when I hit the increase (UP) button it jumps to channel 66 (nothing). I can't get channels in between.
Comments:
Aug 22, 2009
- It is a Sharp 27K-S300.
Thanks
Aug 23, 2009
- Apparantlly there is no MENU button. Just the Channel (up and down) and Volume (up and down) buttons along with the power button. Is there a less expensive universal remote that can do this? Do most of the Sharp remotes (models 1501, 1502, 0797CESA, etc.) that are less expensive also work with this model TV?
And are there codes to be coordinated with the cable company or are these remotes plug and play?
Thanks
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Aug 25, 2009
- Thanks!
Best Solution
posted on Aug 22, 2009
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3802 votes
Hi and welcome to FixYa,
Sharp has made most features and functions available in the MENU. Even without a remote, the MENU button is usually on the front panel control together with the VOLUME and CHANNEL buttons on most models/versions.
Should this MENU button be available in your 27K-S300, then it would be possible to add channels in the SET UP sub menu. On the other hand, the absence of the MENU button on the front panel control would then require that a replacement remote control be purchased.
Good luck and thank you for asking FixYa.
Comments:
Aug 24, 2009
- Pls try:
Cheers.
Solution #2
posted on Aug 24, 2009
Not Rated)
meola64
Rank: Guru
Rating: 88%, 141 votes
You need the remote to get to your settings to be able to program channels. Same thing happen to mine.
Solution #3
posted on Aug 21, 2009
Not Rated)
welcomejee
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3154 votes
Please preform Auto Channel Search in TV by going into Menu. That will store available TV channel data in TV memory and would unlock missing presets too.
If Menu is not being open by front buttons, then surely you need TV remote to do so.
Let me know exact model number and brand to find out replacement remote for your TV.
Thanks.
Popular Solutions for Sharp 27K-S300 27" TV
Questions and Unsolved Problems for Sharp 27K-S300 27" TV
Do you recommend Sharp 27K-S300 27" TV?
Answer
Answer
I need to know what kind of power cord to get for my Sharp tv model 27k-s300
Answer
11 year old Sharp 27K-S300 TV is making static like/loud sparking kind of sound with intermittent... (More)
Answer
Can you tell me what type of fuse I need for RCA tv model F26634SF?
Answer
need part number for flyback transfomer model no 27K - S300
Answer
the auto program feature will only store channels 51 to 72 on cable input. i have perfect reception... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
