Question about Canon imageRUNNER 5000 Copier
About error code
Canon 5000 image runner copier showing error code 350-3000, please give me solution.
  • 4 more comments
  • surendra suryavanshi Dec 10, 2007
    replace cable connected to serial no. port
    o.k.
  • Anonymous Jan 08, 2008
    e000003-0000
  • Anonymous May 03, 2008
    e 247 &e 350 are there when i go to delete error say E-247it is deleted but all of asudden E350 pops.
  • Anonymous Mar 12, 2014
    enter service mode for canon image runner 5000
    error code E000003-0000 canon image runner 5000
Cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
    New Friend:
  • 64 Answers
The E061 code means that the primary charge wire has not set up correctly. I could get more technical and say that the vl is to low. Which means the voltage in the light area is wrong. The E069 means that the transfer and delegation corona didn't set the CD which means voltage in the dark area. In laments terms the top corona and the bottom corona didn't function correctly. With that said this problem was wide spread when the machine got around 1000000 copies. So what has happened is that the lower corona unit arches out thus pulling current from the top so vl and vD could not set. They found that the lower bearing in the fused is ultimily the cause. Keep in mind both entire corona unit need to be replaced I think at 500k. But never done. I replaced every million or when I rebuilt fused . first fused will go 1000000 second about 750k.so it is important to maintain the fused unit. They I mean canon came out with a extra grounding method for the t/s unit.lower corona assembly.it didn't completely fix but helped. My suggestion is either replace entire upper and lower corona assemblies. Or remove clean look for voltage arch marks. You can smell the burn in the housing. A visual is sometimes hard to see . check your bearing if not replace in both upper and lower fused rollers I would rebuild . canon has a q/a kit with all that is needed. Rebuild fused replace both upper and lower corona units. This machine also has a pre-transfer assembly its about at 5 o'clock on the machine. It sometimes is just removed . It will still work your solids suffer on your prints. In a nut shell your leaking voltage in the bottom transfer and seperation unit. Isolate that and that's the fix. There all related. Great machine very strong frame I have seen 20,000,000 on this frame. I have also seen the best of technicians not fix this problem completely. The age of the
Fuser plays a big part in completely fixing this problem. Good luck you got a good one.
Posted on Jan 05, 2015
AM TSEGAYE FROM EAST AFRICA AND I NEED SERVUCE MANNUAL PLEASE WOULD U HELP ME?
Posted on May 12, 2008
Look for a bent pin
rep
Posted on Dec 23, 2007
Canon image runner code E000602-0003
this error is related with the hard drive, maybe is damaged,
May 20, 2014 | Canon imageRUNNER 5000 Copier
My canon image runner 5000 occur error code e000532-0002? how to solve this problem.
this is a stapler issue in the fininisher, it is either off track or something is stopping it from moving or there could simply be staples jammed up
Aug 10, 2011 | Canon imageRUNNER 5000 Copier
I have an error 00315-00d...can u help me to fix it...in canon image runner 5000...thanks a lot
hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
Oct 04, 2010 | Canon imageRUNNER 5000 Copier
Code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
Sep 01, 2009 | Canon Office Equipment & Supplies
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
706 people viewed this question
old marine
old marine
