Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
Samsung 46" LED flat screen TV cannot acsess Caption.
I see the close caption but it is partly hidden  I have addjusted the size of picture but it does not solve problum. When I go to the menu, settings the cabtion is gray and not active to access. Any help out there?
    Genius:
  • Sylvania Master
  • 1,689 Answers
Call the tech support for your TV set. There may be a servcie setup fault, or a component failed that controls the placement of the text, or it may even be a user setup that can be done.
If there is a failure, the set will have to be serviced.
I would guess that you refered to the user manual for any possiblity that there is a setup for the placement of the text...
Jerry G.
Posted on Apr 18, 2008
Can't get closed caption to not appear Samsung led tv series 56
Closed captioning (CC) usually is enabled/disabled as part of initial set up. It also can be enabled by default when the TV speakers are turned off.
Dec 20, 2016 | Samsung Televison & Video
How do I get closed captioning?
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
Mar 13, 2015 | Samsung 6350 Series UN65F6350 65" LED...
Selection of closed captioning usually is accomplished as part of the initial set up procedure.
Sep 25, 2014 | Samsung 46" 5500 Series Full HD Smart LED...
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I make the closed caption bigger. It has a black background and white letters that are too small. How do I fix it?
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
I hope this helps.
Aug 12, 2011 | Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
How can I get closed caption on Samsung 46'' tv?
My 46 samsung has a "cc" button on the remote. Pressing it turns Closed Capt "on" or "off."
Also, from the Plug and Play menu, you'll find "Captions" as an item to manage. "Default" produces smaller, slanted text. "CC1" produces all Caps in a larger text. Unfortunately, one of the selections is not "Mute," where the captions come on when the tv is on "mute." Even cheap crt's have that feature. DOH!!!!
Jul 11, 2009 | Televison & Video
Can't remove the Closed Caption on my Samsung
try putting it in the air channel mode and then see if you can access through menu
Jul 13, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
90 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
