kenmore 580.51650000 dehumidifier: compressor cycles on and off as it should based on humidity setting but the fan is always running, even with the compressor off. Checked humid sensor. Any other suggestions? Thanks
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if...
(More)
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if purchased brand new and if this is a good product. The asking price is $275.00 with 50 ft of hose to drain outside. Thank You for your help, Kristina
small basement efficiency that is not occupied during cold months, and accumulates mold and paint...
(More)
small basement efficiency that is not occupied during cold months, and accumulates mold and paint damage while unoccupied
i have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the...
(More)
i have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and nothing happened but when i went to move it, water poured out everywhere! the water tank is at the top of the machine and there is a small motor at the bottom of the pipe that i think is meant to **** the water up but this does not appear to work....so i took it off and rigged it up to my car battery 12V and sure enough it spins away! so i refitted it and again nothing! does this just kick in when the tank in the unit is full??? the small tank inside the unit is filling up so i think the machine is working. because there is a removeable plug in it and when it is taken out water goes evrywhere! can someone help????? cheers Paddy
