Question about Intel D101GGC Motherboard
Motherboard... i want a complete knowlege of how the MotherBoard works and its internal components....
    Sergeant:
    Champion:
  • 270 Answers
Go to howstuffworks.com
Posted on Dec 03, 2007
Motherboard led red
That sounds like faulty hardware. Remove and replace items one at a time: RAM, video card, etcetera. You might then conclude that one of these components is faulty or that the motherboard is faulty.
Mar 15, 2014 | HP Computers & Internet
My monitor went off, is there any other way to turn the desk top computer off other than disconnecting it? Gateway GT5676
The internal components of the computer are sensitive to electrostatic discharge (ESD). Damage to the motherboard, memory modules, and peripheral cards can occur if these parts are exposed to ESD. If you are familiar with and have a grounding strap, use it while handling any internal components. If you do not have a grounding strap, it is a good idea to touch the computer case anywhere on the bare metal prior to disconnecting the power cord.
Jul 22, 2012 | Computers & Internet
Bios is ok but when start the desktop motherboard was powered off
may indicate a motherboard or power supply failure. try to disconnect all external and internal power and data connections and expansion cards. then install at least the minimum amount of memory needed to power it on, together with the main power connections to the motherboard, the CPU and try to power on the computer. if it works, try to reconnect the other internal cards and devices one by one and test the computer each time to see if any component is causing it or if all components only needed to be reconnected properly
Jan 26, 2011 | IBM (02R4087) Motherboard
Water in mainboard
Replace the motherboard. There are 90% chances that your motherboard is toast.
Cheers
Aug 05, 2010 | Intel Desktop Board D845WN Motherboard
The motherboard 27HRF can work with my dell
You should replace this board it may an internal issue such as a shorted trace of surface mounted component. Not worth the effort to do board level troubleshooting and there are replacement board that will fit the Dell cabinet you have. Call Dell support to make sure that you can use a #rd party board substitution.
I hope this helps. Have a great holiday weekend.
May 29, 2010 | Dell (27HRF) Motherboard
Where do you connect External Speaker to motherboard
Hi
I am providing you with some links one has details of connecting internal speaker to the motherboard, other has complete product guide.
Following link is for complete Product Guide http://downloadmirror.intel.com/15630/eng/DG35EC_ProductGuide01_English.pdf
If you want to connect external speakers you may connect them by plugging the green connetor of the speakers to the green jack / slot which is at the rear / front end of the system. Just look of Green female slot on the system.
On the left side column, where you see Bookmarks, Select Installing and Replacing Desktop Board Components then select Connecting to the Onboard Audio Systems.
You will complete details here on this link.
Regards :)
Apr 26, 2010 | Intel DG35EC Motherboard
Have problem with the motherboard
... Change the ram, and insert all other components on the motherboard well. Also blow out the dust from it. If that doesnt work, change the motherboard completly...
Mar 11, 2010 | HP Compaq Presario F750US
Jumper settings
http://www.chaintechusa.com/
this site is incredibly slow loading (when it wants to) so be patient. you can find the manual for your motherboard here
Robert
Please take a moment to rate this solution thanks
Jan 27, 2009 | Chaintech Slot 1 CT-6ATA2 Motherboard
Intel D101GGC Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
