Question about Eiki LC NB2UW Multimedia Projector
Colors displayed Have owned this projector for 6 yrs with no problems.  Now suddenly all whites have gone to a deep pink color.  Everything else appears to be working normally.  Help!
  • Debbie2008 Jan 08, 2008
    Same problem! This projector has worked fine for about 6 years and now the whites on the screen are pink. We replaced the bulb with a new one with the same results. We even turned the projector on before connecting it with the computer.This projector is used in a public school and we need a solution fast! Thanks.
  • mnar Feb 15, 2008
    the image have a pink shadow
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Posted on Jan 16, 2008
SOURCE:
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
D
Dec 18, 2015 | Televison & Video
SCREEN IS PINK AND NO SOUND..MENU SCREEN COMES UP IN CORRECT COLORS
How to Fix TV Pink Screen, Tech Tips 16 - YouTube
? 0:51
https://www.youtube.com/watch?v=84tyJ6A1frg
Apr 13, 2013 - Uploaded by Tampatec
Turning on and off the TV (not cable box) does recharge thescreen and the colors will properly disperse ...
Why is everything that was white now colored pink on my ...
www.makeuseof.com/.../why-is-everything-that-was-white-now-colored-...
Dec 15, 2015 | Televison & Video
How do i prevent colour bleed from fabrics?
You can't. Best option is not to mix colors with white when doing hot wash. Generally colors on own go well with cold wash with the right detergent. When you get new colored clothes like pyjamas rinse separately overnight to get non fast colors out and then put in the general laundry. But always keep whites on separate wash.
Sep 01, 2014 | Washing Machines
My projector suddenly all the whites went pink
Any solutions yet? mine just did this after 2 months
May 04, 2012 | Optoma PT105 PlayTime Projector
My epson projector is displaying purple,pink and other colors. i changed the chord but still the same problem
means that the lcd panel is fault or the polarizer is burned
Jul 26, 2011 | Epson (DHV13H010L18) Projector Lamp for...
I cut the plugs from the facturay harness for the radio now i am trying to hook everything back up and do not now what colors from the harness goes to the stero. then what the other colors go to that are...
Here are the stereo wiring colors.
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Jan 16, 2011 | 1997 Nissan Maxima
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
Eiki LC NB2UW Multimedia Projector Logo
488 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Mohamad Abdan
Mohamad Abdan
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
