Cuisinart DCC-1200 Coffee Maker Logo
Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coffee brews, then it immediately shuts off.
After the coffee brews, the red light flashed or rather beeps, then it shuts down.
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Aug 21, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
20807
Points
133
The thermastat has come loose or is faulty and needs to be reseated or replaced
Dana Newcombe
Level 3:
President:
  • Master 1,564 Answers
Dana Newcombe
Master
Level 3:
President:
Answers
1564
Questions
Helped
539908
Points
4667
When you set the time for the machine to remain on after brewing you may have set it to zero. Am I in the ballpark?
1helpful
2answers
On/off button doesn't start flashing for descaling on Illy Coffee Machine X7.1
You will know the machine wants to be descaled when the red alert triangle is blinking (lower right part of control pad)
1) Machine must be OFF and cool in order to descale the machine!
2) Fill the water container to MAX with very warm faucet water.
3) Add a packet of Illy / Urnex Dezcal or similar citric acid based descaler to the water, stirring it in until dissolved.
4) Replace the water container into your Illy Francis Francis X7.1 Iperespresso machine.
5) Place a 1L (minimum) plastic catch bowl (or other suitable container) under the brew head AND frothing wand, which should be pointed toward the center of the stage under the brew head (as in video above).
6) Power the machine ON.
7) IMMEDIATELY depress and hold only the BREW (coffee cup symbol) until the machine emits THREE SHORT BEEPS, followed by ONE LONG BEEP. Release the BREW button after the long beep.
8) Press the BREW button again, as you would when brewing a cup of espresso.
9) The machine will begin to PULSE, and the STEAM BUTTON will blink. The machine will alternate between pulsing water through the brew head opening and the frothing wand. This will continue until the water container is EMPTY. Be ready to remove the water container, and IMMEDIATELY refill it with cool (Brita filtered or distilled is best) water, and replace it as quickly as possible. The machine WILL NOT STOP THE DESCALING CYCLE, so replace the water container as quickly as you can. You will probably need to empty the catch bowl at least once or twice during this procedure, and the water will be VERY HOT, so use caution!
10) The machine will continue to pulse between the brew head opening and the frothing wand.
11) The machine will stop pulsing at some point during this second tankful, and the BREW button will begin to BLINK, with an alternating BEEP between blinking. If there is very little water left in the water container, fill it up with cool water again. Empty your catch bowl if it is full and you haven't already done so! Once everything is back in place, press the blinking / beeping BREW button, which will begin to rinse the machine through.
12) The machine may repeat Step 11 more than once!
13) The machine should now come out of DESCALING CYCLE on its own, with the red POWER button illuminated, along with the blue BREW button being on and solid.
14) Run one or two BREW cycles, with cool, filtered water.
15) Run the STEAM cycle for a few moments, as you would when frothing for a beverage, to ensure no descaler remains in the frothing wand.
• Your Illy Francis Francis X7.1 Iperespresso machine is now descaled! see less
1helpful
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
1helpful
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Coffee maker timer does not keep the heat plate on after 10 mins.
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
2answers
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
49helpful
2answers
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
