Question about D-Link AirPlus DI-524 Wireless Router
No web page for installation
I have just connected my new DI 524 but when I type in the address it goes onto a web search page and not the actual logon screen,,,, can u help please, hayley...
  • 1 more comment
  • schippy Jan 07, 2008
    when i type in it will not take me to the logon screen. Please help.
  • Anonymous May 27, 2008
    i key in the same address and nothing appears as it does in the manual
  • Anonymous May 30, 2008
    Got same problem.after typinghttp:// cant download.
    pls help
Make sure you JUST type in the IP address and don't use http:// in front.
Posted on Jan 10, 2008
  • 40 Answers
Just try to reset your router and then make sure that your that ip address was obtain automatically by the router. you can check it by opening the "control panel" then double click the "network connection" then right click the "Local Area Connection" then select "properties" then on the connection type, select the "Internet Protocol (TCP/IP)" by double clicking. then make sure no ip address is manually inputted by selecting "Obtain an IP address automatically" and "Obtain DNS server automatically"
that all.
Posted on Dec 03, 2007
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
-Open the web browser
-Type in the IP Address of
the Router (
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
I have router DI-524 and am unable to connect to internet thru this router. But it says, it is connected
I would do a hard reset by pushing the small button on the back. You will need a small pen to push it. Push and hold down button till the lights flash I would/ say 10-15 seconds should be good enough. Once it's reset try setting up all of your settings again. Remember if you have dsl you will need you username and password to be inputed in some cases. If it is broadband most likely you will not have to bother with username and pass hope this helps.
Nov 30, 2009 | D-Link AirPlus DI-524 Wireless Router
2nd web page not opening
It meight be a problem with web browser try to use it with different browser and Type in the IP Address of the Router (, It will shurely work , for further asistance i am attaching a user manual for your assistance if you need more informatoin kindly message
Thanks Please Rate !
Jun 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Ip address
By default the IP address should be
If it will not accept it
>Make sure your computer is wired or connected to your DI-524
XP version
>Try going start>run > type in CMD
>on the black screen type in ipconfig and hit enter.
>Look for the Default Gateway that would be the IP address that your DI-524 is using.
Windows Vista
>Click Start>All Programs > Accessories > click on command prompt
>type in ipconfig
>Look for IPV4 for the Default Gateway and that would be the IP address of your router.
If not allowing to access the login page, try pressing the reset button for 15 seconds at the back of your DI-524 but pressing the reset button will reset the setting of your wireles setting. Once your press the reset button type in on the address bar and you should be having the login page. use Admin/admin for the username and leave the password blank and click ok...
Jan 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp:// to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the is the IP address of your office, this should work. Be sure you apply a password or anyone going to will have access to you router, I also recommend changing the port from 80 to 8080 so that has to be typed to access the remote management interface.
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 connection
Hi jyothikry firest u configure your madam go to web page and access your ip address then go to in said configure your madam
Jun 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Connection Problem
insatll your drver cd of router if u have connted with a usb cable
then after configar your router
the router defot ip is
type in your web page address bar
the user name is admin & pass: admin
just login & configer
& enjoy
Mar 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
75 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
