Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Seem like the compressor is not working ve...
By breuw on Aug 21, 2009
seem like the compressor is not working very hot to touch does it need coolant
Solution #1
posted on Aug 21, 2009
Somewhat Helpful)
garing
Rank: Wiz
Rating: 82%, 358 votes
clean coils front and back....clean drain oil fan motor...take cover off relay...clean plugs and pins( from oxide)...if it starts hard get a hard start kit
Was this helpful?
Yes
No
Solution #2
Not Rated)
co7196
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 1171 votes
Assuming this is the A/C compressor, right? The compressor will be hot to the touch, the question is whether or not it is engagining when turned on, Check to see if the compressor clutch iis working by having someone turn it on and off while listebibg an observing the compressor clutch. Low refrigerant would or should orevent compressor operation to protect the compressorthrough a safety switch. Good luck
Was this helpful?
Yes
No
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Fan is running but the air coming out is not hot. How to fix the problem
Answer
when i plug in the humidifier there is no power,no lights, nothing.
Describe your Dehumidifiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
in Newport, KY
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
