Question about Toshiba 27AF45 27" TV
Picture settings messed up!
I moved the television from my bedroom to the living room. All of a sudden all of my picture settings are messed up!
First: My picture, in standby video mode, flickers. The "black" is flickering!
Second: I get a doubling with on screen type, I can not correct it with sharpness.
Third: I can't set my tv to a THX optimizer, because the brightness won't stabalize, see "First" above.
Last:The tv was not on since the day before when I moved it, I didn't drop it or tilt it for that matter either. It works this way with either satellite dish hooked up to it through coax or my dvd player to it with the S-video.
Any help would be appreciated.
    Sergeant:
  • 263 Answers
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Posted on Aug 14, 2008
SOURCE:
N64 No Picture on Vizio TV
Well it sounds like a coincidence then. Or if it's working on one tv and not another tv then you need to try a new av cable to see if it makes a difference.
Oct 13, 2012 | Nintendo 64 Console
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Acoustic solution lcd tv
This sounds like the unit is expecting component video input (RGB) rather than composite (yel). Check the settings on the set. The power cord makes no difference.
Keep us posted.
Dan
May 20, 2008 | Televison & Video
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Pink coloration framing my picture
Are there any speakers close to the TV? Move them, as the magnets in them are causing the problem.
If the TV has a 'degaussing' feature, select that.
Try turning off at the power point, waiting for a minute and turning back on... you may have to do this a few times.
Failing all the above, a tech can use a degaussing wand to restore it.
Dec 28, 2007 | Toshiba 32AF43 32" TV
Toshiba 27AF45 27" TV Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
