Alright I'll Explain My Problem In Further Details When I Shut Down My Computer And Want To Turn It On Again It Doesn't Do Anything. I Try To Do It Again By Restarting Or Just Shutting It Down And Start It Again It Wont Work. After About 5 Or 4 Tries It'll Finally Start.
Check your RAM , once remove it and replace..it will set ur problem alright..
I had a similar problem. Hold the ON button in for a few seconds when you turn on your computer.
If it happened after a lot of time switched off, the problem is cold booting.
some times the motherboard BIOS error cause this problem
Set the BIOS settings properly
check the CMOS battery voltage ( 3 volt ), if it less power, replace it
Remove the RAM
CLEAN THE RAM CONTACTS
by softly rubb with a rubber, only on RAM contact
some times the RAM contact may not in contact due to oxide coating,
Thanks For All That Great Info I'll Try Everything But Now My Problem Is Even Worst My computer Doesn't Boot At All Anymore I See The Monitor's Light Flashing And My Cd Drive But Nothing Happends It Just Keeps On Flashing.
