Question about Mitsubishi WT-42315 42" TV
Mitsubishi WT-42313 The television has work perfectly since new, but today it shut off and I can not get it to turn on. When I turn the power on, it starts for about five seconds and then turns off. I've unplugged it and let it cool down, but no change. Do you have any ideas?
  • 4 more comments
  • etalkishere Jan 19, 2008
    Hi Terryfic, my Mitsubishi WT-42315 42" TV I bought from Bestbuy 2003 had similar problem. Its warranty expired last year :( I turned on, it stays on for 3 sec, then turned off right away. I pushed the Input and Menu at the same time, as suggested by some, to display the problem code. The screen stayed dark.
    Do you think I have the same problem as Vetter?
    Do you think replacing/repair DM module would help? Can I do it myself? Where can I purchase the DM module?
    Thank you very much in advance.
    Peter
    Answer posted by Terryfic for this problem:
    DM module needs repair = replace bad capacitors ( bulged tops) with four 1000mf / 25v ........T.
  • hequeen Feb 18, 2008
    I've experinced the same with my WT-42313; found repair procedure for other DM related probelms but not specific for my set. Can someone provide this?
  • Anonymous Apr 01, 2008
    I have the same exact problem.
  • vagabondfrog Aug 23, 2008
    Same thing, click on...clicks itself off in a few seconds. I replaced the StK394-250s because of issue with color. The turning itself off began before changing the ics. I don' t see a particular dm module to replace, although I see other ics near the power entry. I don't see bulging capacitors. Please help!
    Michael
  • Anonymous Oct 10, 2008
    I have exactly the same problem, bought this set in 2004 Jan.
    Has anyone really tried to replace the DM Module? Do I need to ask service center or I can do it by myself if I have little knowledge about TV repair.
    Thanks a lot,
  • etalkishere May 11, 2010
    One more piece of information. Few weeks before this problem occurred, when I press a channel # (202, for example) on my remote to change channel, the TV just sounded "bong", "bong" (2 times if I am not mistaken). After that, it didn't change the channel, I recall. Before, if the channel is not available or not purchased, TV still switched to that channel and showed a message that the channel was not purchased. That shows the TV still got the signal from my Direct TV HD receiver box. I was, however, able to change channel using the +/- on the remote.
    Thanks.
    Peter
    Genius:
  • 1,694 Answers
Posted on Dec 03, 2007
SOURCE:
4-2 error code. Power supply just clicks everytime and shuts off.
I think you mean 2,4 and it is vertical--think this was posted before and I did answer this.
Oct 16, 2012 | Mitsubishi WT-42313 42" Rear Projection...
Blinks on and off Mitsubishi WT-42313 42 in
This is an indication that you have a problem on the power supply section or on the load because of the following reasons :
1. Over Voltage - the regulator might be cycling on over voltage due to lack of load.
2. Over Current Protection - excessive load or faulty power supply cycling will
trigger the over current protection circuit.
3. Leaky Capacitor - a dried up main filter capacitor or other filter capacitor in the low voltage power supply that is producing an out-of-regulation condition until it warms up. A bad filter capacitor on the output of a series regulator may result in excessive voltage and subsequent shutdown.
4. A problem with the microcontroller, relay or its driver, or standby power supply.
This is not DIY and quite technical so I
Jan 19, 2011 | Mitsubishi WT-42313 42" Rear Projection...
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42315 42" TV Logo
331 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
