Back to:
Tags:
Gateway AR-230 DVD Recorder
Gateway AR 230 DVD Recorder will no recognize any... (by 2 users)
posted by nitajjx on Dec 03, 2007
My DVD recorder will not recognize any of my DVDs. Every time I try to play a DVD it just says "NO DISC." It will not even try to load. What should I do?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by per403, posted on Aug 12, 2008
My Gateway AR-230 recorded several disks from VHS tapes sucessfully. The next disk I put in I recorded some VHS onto then turned the unit off to resume later. When I turned it back on it would not recognize the disk. I could not "finalize" the disk as the AR=230 could not read it, it just put onto the screen to insert a disk! I put in a new disk and the screen read it and put "infalid disk" I called Gateway and they had me reset the unit. That did not help. Any suggestions?
Best Solution
posted on May 30, 2008
Thanks for Trying (70)
consumer2
Rank:Apprentice Apprentice
Rating: 90%, 3 votes
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's. Usually any cheep brand will work.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Gateway AR 230 DVD Recorder will no recognize any of my dvds:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
can anyone help with the proper connection from the wall...
I recently encountered a problem where this device will...
is there a code for my Sylvania DVR90vf to my Sony...
hi! I have a sony tv with remote control model #RM-YD010...
I have an external DVD player connected to my Gateway...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
