Question about Acer Aspire 3680 Laptop
Acer aspire 360-2682 notebook
Broken center pin in on-board power cord jack. Need disassembly instructions to gain access so as to facilitate repair.
  • Anonymous Dec 08, 2007
    Sergeant:
    Champion:
  • 270 Answers
Better no to disassemle laptops by your own refer to a qualifying service proffesional
Posted on Dec 03, 2007
SOURCE:
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
My power supply cord doesn't stay connected to the laptop. Is it possible to replace the part in the laptop that the cord connects to?
The power receptacle in the laptop (where you plug the AC adapter cord) has failed. Sometimes the center pin of the connector breaks off, sometimes the solder joints on the main board fail, sometimes there's a break between the connector contacts and the motherboard contacts. In all these instances, you or the technician has to gain clear access to the laptop's motherboard to make the repair. In order to get this done, you might need clear disassembly instructions, as well as decent soldering skills. You could get a replacement connector usually for less than $10, but the repair charge can be several hundred dollars for some models if you take it to a local shop.
Nov 28, 2010 | HP Pavilion ZT3000 Notebook
Electric current does not get through from the adapter to the laptop. the led light does not turn on but the adapter's led light does.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 13, 2010 | Acer Aspire 4315-2963 Notebook
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
Oct 08, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
Sep 28, 2010 | Acer Computers & Internet
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Not working dont get power in motherbord
Sep 23, 2010 | Acer ASPIRE 3680-2022 Notebook
I have an acer aspire 7720g and recently it has been changing from battery to charged by itself, i know this because the battery icon appears in the tool bar. When it does this the power button goes to...
Sep 14, 2010 | Acer Aspire 7720 Notebook
Pin from motherboard is broken. No more power
You'll need to replace the power jack.
Most shops / techs charge $75-100 but that depends on your location.
If you do itself it's about $10 for the jack.
You can get them on eBay fairly easy.
This type of repair is not covered under warranty.
Best of luck!
Jun 18, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 3680 Laptop Logo
205 people viewed this question
Ekse
Alun Cox
