If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
we have had this refrigerator for over 10 years and it has lost temperature and started to defrost...
(More)
we have had this refrigerator for over 10 years and it has lost temperature and started to defrost about 7 times in about a year. each time I have emptied it and left it unplugged for 1-2 says and then plugged it in again but this time it did it again in about a week. would you suggest getting a new one or would this be worth getting a new one?
Hi, Need to know what a control means for GE model DSS25PFMD WW. We know that the Defrost...
(More)
Hi, Need to know what a control means for GE model DSS25PFMD WW. We know that the Defrost heater&bracket assembly needs to be replace. Does the control need to be replace too?
defrost controls check good. main board reads 24vac to 32vac between j9 and j11 when jumping pins...
(More)
defrost controls check good. main board reads 24vac to 32vac between j9 and j11 when jumping pins system works changed main board system had same problem. what can cause this.
Icemaker quit dumping ice, a load is frozen in the tray and when I removed the rear panel, the top...
(More)
Icemaker quit dumping ice, a load is frozen in the tray and when I removed the rear panel, the top half of coils were cold but the bottom half is not. It appears the bottom part of the coil has a lead to the icemaker. Is this my issue and how do I fix it?
