Question about Intel D101GGC Motherboard
How to connect the headphone in front
Please guide me that how to connect the front speaker and head phone socket with motherboard . i have problem as now i connect my head at the back side of the cpu but as soon as i call any body to another pc every time i have to do a setting in accessories of entertainment then i have to go to properties and then i have to select back pin. because as soon as i click to call the setting change to front speaker and mike. so please help me
  • 6 more comments
  • Anonymous Dec 20, 2007
    please tell me that if i connect the spealer pin back side simutaneously if i attach my head phone pin in from will i be able to call to anothere pc without doing any setting please reply.and will it harm my motherboard as my computere person say that it will har ur motherboard
  • Anonymous Mar 12, 2008
    when ima trying toconnect head phone to front headphone port it is not working
  • Anonymous Apr 01, 2008
    my mother board front audio pins don`t start
  • Anonymous Apr 09, 2008
    how to connect the head phones in frount panel
  • karanraj Oct 27, 2008
    front panel audio connection in intel d101 ggc
  • rose_roy24 Feb 07, 2009
    hey hi guys!!
    I have intex headphone & mic jack. i tried connecting it but itz not wrking. is there some kind of a setting to b done?? please help!!
  • kharal Feb 12, 2009
    please guide me that how to connect the front speaker and head phone
  • terry May 11, 2010
    if the motherboard & case both have front connections for headphones you should be able to connect both fron & back .
    what motherboards are you using.
GOOD
Posted on Oct 27, 2008
    Sergeant:
  • 349 Answers
The best solution would be to search out the manual for your motherboard, on the internet ,read it and follow the instructions it gives
good luck
Terry
Posted on Mar 13, 2008
Plz use audio cable extenction
that comes in 2$ at any pc hardware shop
Posted on Dec 17, 2007
I have aproblem with my speakers ( DVD player HCD-DZ720). The front panel shows HP (Head Phone) I checked and the sound comes from Head Phones but not speakers. How can I set the audio to output from...
try to clean the the headphone socket. becous this is preventing the output of the speaker to go out meybe it has jamed the switcher inside the socket
Apr 21, 2013 | Audio Players & Recorders
Headphone connection to 945 gct - hm motherboard
Usually in the "Front Speaker" plug which is lime green usually but not always. Once you plug it in Windows should pop a window asking if you are using headphones or front speakers. Choose Headphones.
Jan 23, 2012 | Intel Motherboard
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
I have recently had my laptop completly serviced and now i have no sound what so ever and no option of being able to change this please help?
Merry Christmas!
Probably, you have problem with your sound driver. Try to reinstall the driver and see if it works.
Check if the speakers or headphones are connected to Light Green colored socket.
It is possible that after servicing, the engineer may have forgotten to connect the front panel connector, if you are trying to connect your headphones to the front panel connector. Try connecting your headphones to the rear panel connector.
It is also possible that the output device, like speaker or headphone is not plugged in properly or not working. Connect something else like other headphone.
Else give more details about you PC Model no. or Mother Board type.
Dec 27, 2010 | Computers & Internet
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Unable to connect my frontech 2.1 one speaker to the laptop the moment i connect to teh headphone socket the sound stops i tried using other speaker in the same head phone socket it work fine . how do...
Did you check the speaker setup in the control panel once you plugged the frontech speakers? Maybe if you define the speaker setup as 2.1 instead of the default stereo it will work.
Jun 25, 2010 | Computers & Internet
I can't hear sound in headphone
1.dear you may be not having the front panel socket on your board,or your cabinet is an oldone and the board is new.
2.Go for the audio drivers check them if they are working properly.
3.if your speakers are working then pull out it's jack and insert your headphone in that if any
pop-up appears then click on to headphone tab.
Dec 25, 2009 | ASUS P5GL-MX Motherboard
They wont give out sound there plugged into the front of the computer and in the outlet plug in BUT IT WONT WORK :( help
Be sure to plug into the "green" socket on the front of the computer, not the "pink" (microphone) or "blue" (headphone output from iPod) socket.
Try the speakers in the "green" socket on the back of the computer, to ensure that the speakers work, and the volume control is "high", and that you have not "muted" your speakers.
Some motherboards have a small "jumper" to enable/disable the front audio-output sockets.
Try the speakers when connected to the headphone-output from your iPod, to confirm that they work -- they could be quite quiet.
Nov 25, 2009 | Koss HDM 11 Computer Speakers
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Intel D101GGC Motherboard Logo
578 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
