Question about Sony DVP-NC650V Multi-disc DVD Player
Tray Opens and Closes Repeatedly After Disc Jam
A disc was jammed in the tray while in Disc Exchange Mode (another disc was playing at the time). I turned the player off, removed the cover and cleared the jammed disc from the tray. Now whenever I turn the unit on the disc tray opens and closes automatically but won't play a disc or respond to any commands. Symptoms: Turn on power, the player hums for a few seconds, the tray opens and player hums again, then tray closes and repeats the same process over and over. I power cycled the unit to no avail. Any help would be appreciated.
  • MartyPres Dec 05, 2007
    I checked the tray and the ribbon cables and they appear fine. Perhaps the problem is related to the fact that there was a disc playing in the player when the jam occurred. After I cleared the jam the disc was still in position to be read rather than returned to the disc tray. It seems that the unit is stuck in 'play mode' and won't release the disc and return to normal operation. Is there a way to reset the player or an override to make it release the disc? Any other ideas?
Tray timing is out of alignment, probably from tray being forced open or closed. Removed cover, removed screw from center of CD turntable, removed two metal clips holding sliding tray down on left side. I ejected tray assembly first and shut off power and unplugged unit lifted left side of tray and experimented with black gear that controls the lifting of disc and the ejecting and retracting of tray. Tried to adjust it to the ejected position as best as possible then powered up and retracted. Next power down and upplugged. Inserted a cd anywhere, note slot # plugged in unit turned on power. Watched disc indicator led's to calibrate with slot if the numbers don't match up, power down, lift up disc turntable to disengage from gear drive near center post and turn to align disc with laser and disc pickup and drive assembly. If tray is not in correct position too align with disc pickup and laser reader assembly lift left side of tray andmove on gear to addjust.
Posted on Aug 29, 2009
I have the same problem. I opened the player and watched the drawer slide in and out. There is a white spindle with a ramp along the inside of the spool. This spindle is supposed to turn and the drawer moves in. As it turns a pin attached to the laser assembly runs along the spindle's ramp. This raises the laser assembly so that it is fully engaged whent he drawer is closed. For reasons I could not discover the spindle was not turning. Further investigation would mean taking out the entire drawer and removing other gears and spindles.
My guess is that repair is more expensive than replacement.
Posted on Aug 22, 2008
    Sergeant:
    Champion:
  • 231 Answers
Check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
SOURCE:
SonyCDP-C800 disc player. Disc tray repeatedly opens and closes instead of just closing.
Disc loading mechanism fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 30, 2016 | Sony Televison & Video
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
Aug 02, 2007 | Yamaha CDC-502 5-Disc CD Changer
Opening/closing game, not very fun.
looks like your switch is jamed or fried, or you installed a modchip incorrectly. If you still are in the return/exchange period, exchange it
Apr 28, 2007 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Sony DVP-NC650V Multi-disc DVD Player Logo
506 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
