Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55PW9363/17F Hi, our 55PW9363/17F  is behaving strangely. On certain channels , like 8 ,and a few others , the picture acts as if it freezes in rectangular portions across the t.v. screen along with the sound . Its as if the picture just slows down to a stop ,and is trying to return to normal. And if we're using the shredder while the t.v. is on,then there's a huge distortion on the picture and the sound until the shredder stops .  Can you tell me what the problem is ?, Can it be repaired ?. Will it be expensive?
    President:
  • 4,402 Answers
You get the distortion when the shredder is on because the shredder is sparking causing the interference. you can check your cables to make sure the have good grounding or just replace the cables.
Posted on Dec 03, 2007
SOURCE:
Hi my polaroid LCD flat screen TV is behaving strange. I've had it almost a year and problems have started the last few days. Basically when I change the channel the screen will go black and freeze. The...
would need the model number but it sounds like a software fault, this can be the control switch chip, does it do this on source to, some times can be fixed with the tv board being clean'd and the dust removed from the board. if there is a lot of dust build up it can cause problems with the micro chips connections you get a statick build up from the dust and make the board do strange thigs
May 09, 2014 | Televison & Video
I have a 5CD changer stereo system. It is very close to the RS2652 and I use it every day in my classroom. Several weeks ago, it began behaving strangely. First I could only get one or two cds to play...
It very well could be a lightning related issue. From previous experience servicing equipment, I have found that electronic equipment that is hit by lightning acts strangely very comparable to what you are describing. Function switches are performing different functions usually due to shorts from the hit. It tends to act normally for bit, and then sporadically do something completely different from what it is supposed to.
As far as service, depending on the age and original cost, you probably are better off getting a new unit. It has also been my experience even if something electronic is repaired, it still may act strangely doing something else later if it was indeed hit. Unfortunately most electronic repair charges can be rather high, maybe 50.00 hr or so, plus parts and a bench fee just to look at it. I have replaced many items for customers after they had them repaired because of this. Check into your insurance. It you have a higher deductable, it may not be worth it. Insurance companies also tend to charge higher premiums as well. Never hurts to ask, but in the long run a drive to the store might be worth it.
Feb 19, 2011 | RCA Audio Players & Recorders
Sometimes when changing channels it indicates "no input". Sometimes you can go to previous and then back and the channel will come up, other times, you need to power off and back on as the TV totally...
This actually sounds more like a signal issue on the cable box. When you go from regular digital chs to HD channels sometimes boxes will distort or pause the picture when changing channels (it's not the cable or satellite, it's your TV trying to read the different format of the chs) this is normal. Also, some TVs may need to have a firmware update and you can normally get it from the Manufacturer's website
Apr 30, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9431d/37 behaving erratically
I would have the technician check out the key board assembly (button panel for lamen's terms). If not,then it could be a problem on the IR reciever board that is causing the small signal board to behave rather unusually. Tell him to check the ir board,there should be a surface mounted capacitor that will read shorted on a diode scale under the infra red diode. If that solves it,then it should cost you no more than 60$ reasonably. The logic board wouldn't have anything to do with the button changing.
I have also worked on a lot of this whole series of philips plasmas, and the control board is the least likely suspect from my experiences
Oct 16, 2009 | Philips 42PF9431D/37 TV
Very odd tv problem
Digital receivers whether external to the TV (converter box, satellite) or built in are digital processors(computers). Just like computers there are times when they freeze up. This can happen if the data stream is corrupted too much to render the picture, but enough signal to lock. The processor attempts to "wait" long enough to gather enough information to begin. Just like computers, these need to be re-booted by turning on or off and sometimes unplugged and plugged in. You have either too low of signal quality or too high of signal strength, which is a problem with digital receivers.
Mar 03, 2009 | Hitachi 42HDS69 42 in. Plasma Television
No color output from philips 751/171 dvd player
Hello.
The RF modulator sends on a certain frequernzy(Channel) usally around channel 36 on UHF. If there is a adjustmen screw on it try and turn it util the picture disapears and then search for it on the tv again just to make sure nothing else is interfearing on the channel the RF modulator is sending on now.
An alternative if there is no adjustment on your RF modulator would be to change the frequenzy on your VCR or other devices attached to your TV that might send on the same frequenzy as your RF modulator.
Regards..
/Tech5508
Feb 15, 2009 | Philips Televison & Video
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
483 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
