Question about Sharp Actius AV18 Notebook
MY COMPUTER WONT WORK
I TRIED TO DO SYSTEM RESTORE ON MY ACER5100 AND IT STATED RESTORE FAILED AND IT RESTARTED THE COOMPUTER NOW IT SAYS NTLDR IS MISSING, AND WHEN I TRY TOO ACCESS THE SETUP MENUS IT ASKS FOR A PASSWORD, I NEVER SET A PASSWORD FOR MY COMPUTER AND THE ZERO'S DONT WORK....WHAT CAN I DO?
    Sergeant:
    Champion:
  • 270 Answers
Ur computer may be infectedby some virus .. format the system parttion using some linux live cd parttion tools and try to reinstall the requird os
Posted on Dec 03, 2007
Acer aspire one restore failed: wont start now
the reason its saying,,ntldr is missing is because its lost somthing from the hard drive that it needs to run,it would have lost that when it stopd loading your windows.try it again and if it gives you..repair windows ,,,then do that.and it should do it because it should fint the missing file that it needs to carry on loading.
May 04, 2014 | Acer Aspire One Netbook 8.9" Notebook
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
NTLDR is compressed
u need to reinstall your OS with the same Key that your pc came with
Oct 08, 2012 | eMachines eMachine w3502 512MB DDR PC-3200...
NTLDR is missing Press Ctrl Alt Del to restart
The issue is your system is not loading off of the boot drive- check for usb keys, floppies, even sometimes cds can cause the issue. If that does not work, you'll need to get your copy of windows, boot to that disk, and run a chkdsk /r in the repair option. If that does not work, you will need to reinstall Windows.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 17, 2010 | Acer Computers & Internet
Corrupt harddrive
You state that you have pulled the pins out of your harddrive. If the harddrive is physically damaged then the data cannot be recovered economically. Do not try to take the disks out and put it in another drive: you will loose another one in the process.
I suggest you take the drive to a computer repair shop and see if the drive board can be changed.
Once the drive is working then install it as a slave on a working system, copy all your files to another location and format you old drive.
After formatting you have a choice to discard it (if it is old) or reinstall windows on it.
Aug 12, 2009 | Microsoft Windows XP Media Center Edition...
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Computer crashed and will not restore.
if u tried installing windows from a CD onto the HDD and it still says missing ntldr. seems like a Bad hard-drive.
you can restart by pressing control-alt-delete.
then, try booting from windows CD and repairing the windows installation. if it gives u file copy errors.then, it is a HDD failure. get a new HDD.
Mar 30, 2008 | Acer Aspire 5100 Notebook
Sharp Actius AV18 Notebook Logo
94 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
