Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 WISH TO VIEW PAL SIGNAL IN HD
I have the above US TV and I now live in Australia where the signal is braodcast in PAL format. I understand that the TV is an NTSC format, is there a box I can buy to convert the HD signal from my set top box to NTSC so I can view a descent picture? Would a DVDO upscaler or similar help? Also when I watch DVD's through my DVD player there is noticable judder in certain animated scenes like LOTR for example. Any ideas on how to overcome this?
Thanks
  • Anonymous Dec 26, 2007
    i have the same problem brought my canadian rca back to the uk
    mick
    President:
  • 4,402 Answers
Http://www.world-import.com/samar.htm
Posted on Jan 08, 2008
How can get a channel for a kogan tv from australia brought to philippines?
You might not be able to do this. Broadcast TV signaling standards vary by the region in which they are from; there are a few. NTSC and PAL. If your TV signal amplifier system is for NTSC broadcast standards but your incoming signal is from a PAL standard or vice versa; you will not able to view that channel. Refer to your manual for what TV broadcast system it is compatible with. Some TV's system setting can be changed.
Dec 14, 2014 | Televison & Video
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
I bought this tv, more or less 4 years ago, and I'm live in brazil. So, when I got here the Tv was black and white, no color! What's wrong? Can we help me?
Depending on where the set was purchased (USA) it may be NTSC format and Brazil is likely to be different format like PAL or even Seacam---they do make converter boxes that will convert signal from one format to another.
May 01, 2012 | Dell W2306C 23 in. HD-Ready LCD Television
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
I have a D52W20. I bought a HDMI cord thinking it was what I need, what is it that I DO need for HD?
To correctly get HD, you need to satisfy three things.
First you need an HD tv.
Second you need an HD signal. IE.. HD cable box, Blu Ray etc..
Last, you need either HDMI wires or Components wires.
Hook the HD box up to the TV with component wires(I believe you tv doesn't have hdmi connections), go to the correct input and enjoy.
Feb 20, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Format to large on rca hd tv
use the remote to change the picture aspect ratio
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 and PS3
I have a problem my tv dont power do you now what can I do?
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Not working
first you should know that the uk system is pal and the usa system is ntsc. ok connect your cable box using the rca cable to your converter then out of your converter to you tv. the converter box should have buttons for out and in now remember that pal signal is going in to your converter (it should automatically selected it) but you would probly have to select the signal that is going out of the convert and the signal going out is ntsc so make sure u select out signal to be NTSC. hope i could help
Apr 02, 2008 | Samsung SV5000W VHS VCR
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
