Question about LG LRTGC1815 Top Freezer Refrigerator
0 characters
1 Points
Water Filter Status Light
Could I get a model number to research how this light works, most led light are powered by a low voltage circuit and you my just have a bulb out. So a model number you assist me to get the correct infromtation to your model in questioned. Thanks
Aug 31, 2014 | Whirlpool Refrigerators
Changing the light bulb on display control panel
The bulb is located behind the panel under the light cover and this unit takes four bulbs to light up the refer section. The bulb you seek is directly behind the display and computer unit mounted to the celling of the refer section.
Good Luck
Nov 01, 2013 | Sub-Zero 690 Side by Side Refrigerator
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
Fridge is not cooling
A failed start relay could be the culprit. The relay/overload assembly (12555902) and the run capacitor (C8931612) should be replaced.
Be sure to unplug the refrigerator prior to service.
Apr 27, 2009 | Maytag MBB2256G Bottom Freezer...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
LG LRTGC1815 Top Freezer Refrigerator Logo
13 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
