System unit it does'nt work after i turn on my computer but the power supply is running.
  • 56 Answers
Dead mobo main possibilty.
You could try reseating the RAM and the AGP / PCI cards if you have any.
If neither of those work its your mobo =(
Posted on Dec 03, 2007
No power
there should be a power down DC board that will supply dc voltage to the electronic components i think your problem can be found there
Apr 16, 2014 | RCA RS2622 CD Shelf System
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
When does the humidifier fan start? Does the water flow trigger it? Will the fan nt start if I turn off the water supply?
Humidifier should be powered from the furnace heating 24 volt terminals through a humidistat and then to your humidifier. The fan and the water solenoid on the unit should come on together. if the water is not turned on the fan should still run, unless the unit is not plugged in.
Nov 13, 2010 | Aprilaire 700 Humidifier
Computer not working
Try to reseat the connectors on the mother board.
Feb 21, 2010 | NEC (190300) 235-Watt Power Supply
OCZ 700 watt powers up but computer will not boot into post
I know this one can be frustating. More than likely the power supply is no good. There is a fairly high surge when you first turn on a system. If the supply sags, the system may not start. I had this ussue before. When I would just barely pull the power cord out, just enough to break the circut for a split second, sometimes the unit would boot. This is because all of the capacitors at the processor supply rail are charged, therefore less of a surge.
Apr 11, 2009 | OCZ GameXStream (OCZ700GXSSLI) 700-Watt...
My computer wont turn on
Sound like 'classic' failing capacitor symptoms to me... RMA the power supply if you're able to, start scraping together some cash for either a rebuild (replace capacitors) if you can't OR purchase a NEW PSU
Once you get the system running... I would recommend you leave it turned on 24/7 as this will keep the failing capacitors at a static temperature (instead of the heating/cooling cycle) thus milking the last bit off life out of it while you secure a replacement unit.
Jan 15, 2009 | Cooler Master (RS-380PMSR/P) (RS380PMSRP)...
Enhance Power Supply only works unconnected to computer
Hi when under load the PSU voltage is obviously dropping off, With a Power unit, there are 3 things to keep in mind. They are too expensive and too dangerous to repair, Also inexpensive to replace. Regards mistyman
Sep 29, 2007 | Enhance Technology SFX-1211J, Enhance 110W...
Windows NT operating system
Your Kodak EasyShare digital camera will not work directly with a computer running the Windows NT operating system. The Windows NT operating system does not support the universal serial bus (USB) standard, and all Kodak EasyShare digital cameras communicate using the USB standard. However, you can transfer pictures from your camera to your computer by purchasing a parallel port card reader. Take the memory card with pictures from the camera, insert the memory card into the card reader, and then copy the pictures from the memory card to the computer.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
